I have been trying to install the only office document server for 4 days now. I have tried using the docker method. Everything appear to go right with the docker method, but when I go to http://localhost then only the default apache 2 page is there. Or if I make the apache 2 disabled then enable lighttpd or nginx then same outcome but just different home pages. I also tried using no-ip for a domain use of server access and I tried http://xxx.x.x.x I also tried sudo bash then apt-get install onlyoffice-document-server method which returned repositories not found error
User98764431
  • 569
  • 33
This is a futile endeavour. The System requirements for Document Server include:
  • CPU: dual core 2 GHz or better → while Raspberry Pi 2 & 3 have quad-core processors, they're ~ 1 GHz ARM quad core. Server spec software usually assumes Intel power per core
  • RAM: 2 GB or more → the most RAM that a Raspberry Pi supports is 1 GB
  • OS: 64-bit Debian, Ubuntu or other compatible distribution → almost all Raspbian OSs are 32-bit
No model of Raspberry Pi can meet these requirements.
scruss
  • 9,117
  • 25
  • 36
Now Raspberry Pi 4 is quad core, 1.5Ghz, up to 8 Go RAM.
This seems to be possible now, following these guidelines :
https://help.nextcloud.com/t/tutorial-installing-onlyoffice-server-on-raspberry-pi-4-ubuntu-server-20-10/100739
It is not trivial though, for experienced users I guess.
