I've just bought a new Raspberry Pi Zero W v1.1 2017 and i already have a connection problem with putty over ssh.
Things i've done so far:
downloaded 2017-09-07-raspbian-stretch.img and burned with Win32DiskImager on micro sd
created an
sshfile in the root foldercreated
wpa_supplicant.conffile containing:network={ ssid="Redmi4N" psk="12345678" key_mgmt=WPA2-Personal }
*also tried with key_mgmt=WPA2-PSK or without that line
When i try to connect with putty at raspberrypi i get the following error:
Unable to open connection to raspberrypi Host does not exist.
*same thing for raspberrypi.local as a host
Then, i've tried to check the connections with Advanced IP Scanner as i have read on forums but still nothing; it is not shown in there.
Am i doing something wrong? What else shoul i try?
PS:Using Windows 10 and the latest version of putty.
