I'm designing a kiosk device with a Raspberry Pi.
The device is powered down by removing power without warning (not by graceful shut-down).
If a USB drive is mounted at the time (say "SanDisk"), at the next power-up, the "SanDisk" folder is still present in /media/pi/ (though inaccessible), and a new folder, "SanDisk1", appears.
After 100 times, there are 100 folders in /media/pi/, from "SanDisk1" to "SanDisk99".
What's the best way to clear the ghost USB folders from /media/pi/?
I can use a Python script.
The "best" solution is to mount the drives explicitly, and unmount before shutting down, rather than relying on automount and tidying up the mess after.
Create a rule in /etc/fstab to mount the drives in a dedicated folder.
I use the following to mount one of my drives, although you will need to substitute settings appropriate for your drives.
UUID=94dc6686-0eda-41ba-87f7-494d7e37f913       /mnt/PiData     ext4    defaults,noatime,noauto  0     0
You should also implement some means of shutting down properly. If you continue to just turn power off, you will eventually corrupt the image, and possibly the mounted drive
You could delete all the folders on reboot using a cronjob.
crontab -e
then adding
@Reboot * * * *  rm -rf /home/pi/*San*
Be careful as this will remove ALL folders and files starting with "San" and is also case sensitive
Dr.Rabbit
  • 1,016
This code deletes all the folders (ghosts or otherwise) from the media folder. A bit later, the system mounts the USB drive that is truly present
MEDIA_DIR = '/media/pi'
def clearGhostDrives():
    """Delete non-existent USB drives"""
    # When power is removed (no shut-down) and a USB drive is removed,
    #  then the power is restored, a ghost folder is left in /media/pi/
    # Distinguishing between ghost folders and real ones has proven to be too much of a challenge
    # Instead, this function deletes all the USB folders
    # This is executed when powering up, before the USB drive is mounted
    # Therefore, after this removes all the folders, the system mounts the USB drive that actually exists
    # Locals
    DEL_DIR_CMD = 'sudo rm -r %s/%s'
    usbDrivesList = os.listdir(MEDIA_DIR)
    if len(usbDrivesList) > 1:
        for usbDriveName in usbDrivesList:
            doLinuxCmd(DEL_DIR_CMD % (MEDIA_DIR, usbDriveName))
