Using Python3, I want to read data on a serial port and display it into a tkinter GUI text window (not only the shell). Pretend I am trying to make the equivalent of a serial port character display.
I think I am running into the problem where the GUI blocks the rest of my main program but am not sure and not sure what to do next.
When I run my code I get the GUI window. When I close the window then serial data starts appearing in the python shell.
Trying the following code
#!usr/bin/python3
#Filename: gui_serial_blocking.py
#Date: 30 September 2017
#Trying to receive serial port data into GUI text window.
#https://raspberrypi.stackexchange.com/questions/73148/want-to-read-com-port-data-and-write-into-tkinter-text-window
from tkinter import *
class Application(Frame):
"""Build the windows to show 20x10 Customer Pole Display data"""
def __init__(self, master):
super(Application, self).__init__(master)
self.grid()
self.create_widgets()
def create_widgets(self):
self.label1 = Label(self, text='Text window for data from serial port:')
self.label1.grid(row=0, column=0, sticky =W)
self.text1 = Text(self, width=20, height=2)
self.text1.grid(row=1, column=0)
self.text1.focus_set()
def writeDisplay(self,inputCharacter):
myCharacter = inputCharacter
varText = self.text1.get("1.0", END)
varReplaced = varText + myCharacter
self.text1.delete("1.0", END)
self.text1.insert(END, varReplaced)
def openDisplay(self):
root = Tk()
root.title('Text widget test')
root.geometry('360x250')
#app = Application(root)
app.mainloop()
class mySerialport():
import serial, time #initialization and open the port
global ser
ser = serial.Serial()
ser.port = "/dev/ttyUSB0"
#ser.port = "COM2"
ser.baudrate = 9600
ser.bytesize = serial.EIGHTBITS #number of bits per bytes
ser.parity = serial.PARITY_NONE #set parity check: no parity
ser.stopbits = serial.STOPBITS_ONE #number of stop bits
#ser.timeout = None #block read
ser.timeout = 1 #non-block read
#ser.timeout = 2 #timeout block read
ser.xonxoff = False #disable software flow control
ser.rtscts = False #disable hardware (RTS/CTS) flow control
ser.dsrdtr = False #disable hardware (DSR/DTR) flow control
ser.writeTimeout = 2 #timeout for write
#possible timeout values:
# 1. None: wait forever, block call
# 2. 0: non-blocking mode, return immediately
# 3. x, x is bigger than 0, float allowed, timeout block call
def myOpenSerialPort():
try:
ser.open()
except serial.SerialException:
print ("error open serial port: " + ser.port )
exit()
def myReadbyte():
if ser.isOpen():
try:
response = ser.readline(1)
return(response)
#except Exception, e1:
print ("error communicating...: " + str(e1))
else:
print ("cannot open serial port ")
if __name__ == "__main__":
root = Tk()
app.mainloop()
#Open the serial port and get date.
mySerialport() #Create serial port.
mySerialport.myOpenSerialPort() #Open the port.
#Get serial data forever and write to GUI
while(True):
#getting serial data
foo= mySerialport.myReadbyte()
#writing serial data to display.
#Application.writeDisplay(foo) #Place holder for writing to GUI text window.
#For development, print to shell instead.
print(foo.decode())
