Hi I want to use the BLE on my raspberry pi 3 Jessie. But I'm not able to get it working.
Bluetooth is loaded, active and running
$sudo su
$apt-get update
$apt-get install bluetooth bluez blueman
$service bluetooth start
$systemctl status bluetooth
bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
   Active: active (running) since Tue 2017-09-12 15:38:58 UTC; 1h 51min ago
     Docs: man:bluetoothd(8)
 Main PID: 1419 (bluetoothd)
   Status: "Running"
   CGroup: /system.slice/bluetooth.service
           └─1419 /usr/lib/bluetooth/bluetoothd
Sep 12 15:38:58 grassberry systemd[1]: Starting Bluetooth service...
Sep 12 15:38:58 grassberry bluetoothd[1419]: Bluetooth daemon 5.23
Sep 12 15:38:58 grassberry systemd[1]: Started Bluetooth service.
Sep 12 15:38:58 grassberry bluetoothd[1419]: Starting SDP server
Sep 12 15:38:58 grassberry bluetoothd[1419]: Bluetooth management interface 1.14 initialized
Sep 12 16:39:06 grassberry systemd[1]: Started Bluetooth service.
Using bluetooth
$bluetoothctl
$list => no result
$scan on => no default controller
Modprobe:
$modprobe bcm203x
modprobe: ERROR: ../libkmod/libkmod.c:557 kmod_search_moddep() could not open moddep file '/lib/modules/4.9.24-v7+/modules.dep.bin'
$modprobe btbcm
Other solutions I found and tried
Hcitool
$hcitool scan
Device is not available: No such device
I tried diff. things and rebooted inbetween: Installing raspberrypi-sys-mods: Raspberry Pi 3 Bluetooth "No default controller available"
Upgrading everything:
$sudo apt-get update
$sudo apt-get upgrade -y
$sudo apt-get dist-upgrade -y
$sudo rpi-update
With hci
$sudo hciconfig hci0 up
Can't get device info: No such device
$hciconfig -a => nothing
$sudo systemctl start hciuart.service
Job for hciuart.service failed. See 'systemctl status hciuart.service' and 'journalctl -xn' for details.
$systemctl status hciuart.service
● hciuart.service - Configure Bluetooth Modems connected by UART
   Loaded: loaded (/lib/systemd/system/hciuart.service; enabled)
   Active: failed (Result: exit-code) since Tue 2017-09-12 18:05:05 UTC; 37s ago
  Process: 1762 ExecStart=/usr/bin/btuart (code=exited, status=1/FAILURE)
Sep 12 18:05:05 grassberry btuart[1762]: Initialization timed out.
Sep 12 18:05:05 grassberry btuart[1762]: bcm43xx_init
Sep 12 18:05:05 grassberry systemd[1]: hciuart.service: control process exited, code=exited status=1
Sep 12 18:05:05 grassberry systemd[1]: Failed to start Configure Bluetooth Modems connected by UART.
Sep 12 18:05:05 grassberry systemd[1]: Unit hciuart.service entered failed state.
Installing pi-bluetooth
$apt-get install pi-bluetooth
I got I2C and wifi running.
Mike Poole
  • 220
Andi Giga
  • 541
What UART devices are you using? On board bluetooth requires the full UART device (UART0) which, if enabled, will cause the serial console to be mapped to /dev/ttyAMA0. You can check your /dev directory with the following command:
ls -l /dev | grep ttyAMA0
You should get something like the following:
output of terminal command
If you run the same command from above, replacing ttyAMA0 with ttyS0 and that appears in the /dev directory, you're using UART1 otherwise known as mini-UART.
To enable the ttyAMA0, you must first disable ttyS0 with the following command:
sudo systemctl stop serial-getty@ttyS0
Comment out the device tree in /boot/config.txt
sudo nano /boot/config.txt
While nano is opened, look for the following and comment it out by adding a '#' in front of the text:
dtoverlay=pi3-miniuart-bt
ctrl-X and save changes. Then reboot your Pi
sudo reboot
After the pi has reboot navigate to /boot/cmdline.txt
 sudo nano /boot/cmdline.txt
Enable the serial console by adding the following to the bottom of the file:
console=ttyAMA0, 115200 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
save changes by hitting ctrl-x and reboot your pi once more.
sudo reboot
Niko_Jako
