I want to create a tensorflow based detection system in an IOT setup. Will it perform better if I run it on Android Things or Raspbian? I expect to be using Full Yolo or tiny Yolo running on tensorflow. I am using Raspberry Pi 3.
Also please suggest any other OS if it is better than these two.
I know this is a relatively old question (1 year) but I came across a similar issue so here is what I did.
I would go for Raspbian, since this is officially supported by Tensorflow.
Note: Raspberry Pi device must be running Raspbian 9.0 or higher
Make sure you have Python 2.7 or Python3.4+ installed on your system, as well as pip or pip3. If not, you can follow the instructions to install Python here, and pip here.
You can follow the TensorFlow docs for a proper installation.
rrz0
  • 123
