I have a Pi3 connected via Ethernet to my router. I have configured router (not the Pi) to associate static IP addresses to the MAC addresses of eth0 and wlan0. When I boot up the Pi and run ifconfig, I can see that eth0 was assigned the correct IP, however wlan0 is up but does not have an IP assigned. Why is this? Btw, there is nothing in particular I am trying to achieve. Just playing around with the hardware.
I have played around with /etc/network/interfaces what I describe above happens under the setting
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
auto wlan0
iface wlan0 inet dhcp
I have not configured wpa_supplicant. What I am trying to understand is how one could assign an IP to the wlan0 interface without connecting the pi via said interface. My naive understanding is that since the Pi is connected via Ethernet, and the WiFi interface is on the same piece of hardware it should be "discovered" and an DHCP running on router should assign IP, but obviously that's not how it works. So what am I missing?
grather_columbia
A dhcp server assigns an ip address to each connected interfaces in the network. While your wifi is on the same board as the ethernet, your wifi does not send any data through the ethernet cable, right?
So the wifi is only physically connected and has no actual links to the network, hence no ip address ia assigned.
akgren_soar
  • 221
Have you configured Pi's /etc/network/interfaces file? More info here: How do I set up networking/WiFi/static IP address?
PaHa
