Recently I purchased a few MCP23017. I've been reading up on them and I've gotten a few lights to turn on and such. I am having a problem trying to understand how to figure out the register address for each pin. In this one tutorial I read, they used pin 23 which is 0x14 but I cant seem to figure out how to come at that number. Seems like a lot of tutorials link to this diagram, http://hertaville.com/wp-content/uploads/2013/03/mcp23017_mm.png so can someone help me figure out how to read this. Since hex 14 is 2nd last wouldn't that make its pin 26 and not 23?
Also, I think I've gotten the daisy chaining working properly with multiple of these but just to make sure: To change the hex value of x20 I just change a0-3 to be not ground? One of my chips is getting really hot (luckily I have 10 of them) but it gets detected by the pi in i2cdetect -y 1 as x21 so I figure its correct. Could it just be a faulty chip?
Thanks guys!
Joe Jankowiak
Pin numbers
Your chip has 16 I/O pins that are divided in two groups of 8 pins each, called bank A and bank B. Physical pins 1-8 of the chip are used for bank A pins and physical pins 21-28 are used for bank B pins. Rest of the physical pins (9-20) are used for other purposes like setting the device address, connecting power and ground, etc.
The device has quite a few registers that can be individually written/read in order to perform different operations. Two of those registers are GPIOA (0x12) and GPIOB (0x13) 8-bit registers that can be used to read/write whole bank A or bank B at a time. This means that if you read GPIOA register, you will get 8 bits of data and each of them will give you the value of different pin in bank A. The same goes for writing - if you want to write some value to any pin in bank A, you have to write whole GPIOA register setting values of all pins in bank A at once.
How to calculate bank value
As already mentioned, each bank consists of 8 bit which corresponds to 8 pins values. Here's how the value is computed for bank B:
P8  P7  P6  P5  P4  P3  P2  P1
and here is for bank A:
P28 P27 P26 P25 P24 P23 P22 P21
where each of PXX corresponds to physical pin number XX.
So if you want to turn P21 and P25 on and P22, P23, P24, P26, P27 and P28 off, you would write value of 00010001 (in binary) which is 0x11 in hexadecimal to the GPIOA register.
I²C Addressing
Each of your A0, A1 and A2 pins should either be connected to ground or to VCC, depending on the address you want to get. You should never left it without any connection since this will make it float. This means for the chip it may have different state each time it is read. So if you want to have address 0x20, you should connect all of them to ground. If you want to have 0x27, you should connect all of them to VCC.
Final notes
Please note that this is simplified explanation of how this chip works. It has different mode of operations and some more features that can be configured using chip's registers. You can read about such details in the datasheet.
Krzysztof Adamski
  • 9,605
  • 38
  • 53
