Sorry but I'm loosing my mind with the Wifi on Rapsbian Jessie.
Here is the thing : At work we have a secure Wifi connection. We had instructions to get connect via ANDROID terminals, as following :
EAP: TTLS
Phase2: PAP
Login: MY@LOGIN.COM
Password: MYPASSWORD
Proxy->Manual
proxy.wifi.MYWEBSITE.COM
Port: 8080
It works fine.
But when I want to do the same on my RPi 3 .... the Wifi GUI doesn't support this, I installed Wifi-radar, but I can't find the field the put this setting.
I came to understand I need to edit wpa_supplicant.conf in /etc/wpa_supplicant/. So I used the help about wpa_supplicant.conf and added the following code (using sudo nano wpa_supplicant.conf) :
network={
ssid="MYWIFI"
key_mgmt=WPA-EAP
eap=TTLS
identity="MY@LOGIN.COM"
password="MYPASSWORD"
phase2="auth=PAP"
But even after a reboot, nothing.
As for the proxy setting i understood i had to create a 10proxy file in /etc/apt/apt.conf.d/ and write within this file : Acquire::http::Proxy "http://proxy.wifi.MYWEBSITE.COM:8080/";
but even after a reboot...nothing. What should I do?
