I have a PI3. I've tried installing pybluez with:
pip install pybluez
and
pip3 install pybluez
Both fail with:
Command /usr/bin/python3 -c "import setuptools,
  tokenize;__file__='/tmp/pip-build-2yikecdn/pybluez/setup.py';
  exec(compile(getattr(tokenize, 'open', open)
  (__file__).read().replace('\r\n', '\n'), __file__, 'exec'))"
  install
  --record /tmp/pip-sx4_w49r-record/install-record.txt
  --single-version-externally-managed --compile
failed with error code 1 in /tmp/pip-build-2yikecdn/pybluez
Storing debug log for failure in /home/pi/.pip/pip.log
I really need to use pybluez. Can anyone help me out?
Thanks a million!
Patrick
  • 103
Damon
  • 41
Finally found an answer to the issue. Need to do the following to get pybluez installed on Raspberry Pi 3
sudo apt-get install libbluetooth-dev
sudo apt-get install python-dev
sudo pip install PyBluez
The first two install the appropriate header files that are missing.
Jacobm001
  • 11,904
  • 47
  • 58
Damon
  • 171
