Deluge have no init scripts in raspberry pi repository?
root@rpi ~# service deluged start
deluged: unrecognized service
root@rpi ~# service deluge-web
deluge-web: unrecognized service
But deluged and deluge-web are installed :(,
SlySven
  • 3,631
  • 46
Someone1234
  • 121
deluged init script
Instructions
  • sudo wget https://gist.github.com/earthmeLon/a4bf68d385f8f840d2b5/raw/ -O /etc/init.d/deluged
    • This downloads the script and places it in the correct directory
  • sudo chmod +x /etc/init.d/deluged
    • This allows execution of the new file, which is essential for it to be run at startup
  • sudo update-rc.d deluged defaults
    • This loads the default init settings for deluged
  • sudo update-rc.d deluged enable
    • This turns on the loaded settings for deluged so that it will be loaded at boot
CLI/Old Script
#!/bin/sh
### BEGIN INIT INFO
# Provides:          deluged
# Required-Start:    $local_fs $remote_fs
# Required-Stop:     $local_fs $remote_fs
# Should-Start:      $network
# Should-Stop:       $network
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Start or stop the Deluge BitTorrent daemon.
# Description:       Start or stop the Deluge BitTorrent daemon.
### END INIT INFO
Authors: Tanguy Ortolo <tanguy+debian@ortolo.eu>,
Cristian Greco <cristian@regolo.cc>
PATH=/sbin:/usr/sbin:/bin:/usr/bin DESC="Deluge BitTorrent Daemon" NAME="deluged" DAEMON=/usr/bin/$NAME DAEMON_ARGS="-d -c /var/lib/deluged/config -l /var/log/deluged/daemon.log -L info" USER=debian-deluged MASK=0027 PIDFILE=/var/run/$NAME.pid SCRIPTNAME=/etc/init.d/$NAME
Exit if the package is not installed
[ -x "$DAEMON" ] || exit 0
ENABLE_DELUGED=1
Read configuration variable file if it is present
[ -r /etc/default/$NAME ] && . /etc/default/$NAME
Load the VERBOSE setting and other rcS variables
[ -f /etc/default/rcS ] && . /etc/default/rcS
Define LSB log_* functions.
Depend on lsb-base (>= 3.0-6) to ensure that this file is present
and status_of_proc is working.
. /lib/lsb/init-functions
Function that starts the daemon/service
do_start() { if [ $ENABLE_DELUGED != 1 ]; then log_progress_msg "Not starting ${DESC} ${NAME}, disabled in /etc/default/${NAME}" else # Return # 0 if daemon has been started # 1 if daemon was already running # 2 if daemon could not be started start-stop-daemon --start --background --quiet --pidfile $PIDFILE --exec $DAEMON
--chuid $USER --umask $MASK --test > /dev/null
|| return 1
start-stop-daemon --start --background --quiet --pidfile $PIDFILE --make-pidfile --exec $DAEMON \
  --chuid $USER --umask $MASK -- $DAEMON_ARGS \
  || return 2
fi }
Function that stops the daemon/service
do_stop() {
Return
0 if daemon has been stopped
1 if daemon was already stopped
2 if daemon could not be stopped
other if a failure occurred
start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --pidfile $PIDFILE RETVAL="$?" [ "$RETVAL" = "2" ] && return 2
rm -f $PIDFILE return "$RETVAL" }
case "$1" in start) [ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME" do_start case "$?" in 0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;; 2) [ "$VERBOSE" != no ] && log_end_msg 1 ;; esac ;; stop) [ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME" do_stop case "$?" in 0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;; 2) [ "$VERBOSE" != no ] && log_end_msg 1 ;; esac ;; status) status_of_proc "$DAEMON" "$NAME" && exit 0 || exit $? ;; restart|force-reload) log_daemon_msg "Restarting $DESC" "$NAME" do_stop case "$?" in 0|1) do_start case "$?" in 0) log_end_msg 0 ;; 1) log_end_msg 1 ;; # Old process is still running ) log_end_msg 1 ;; # Failed to start esac ;; ) # Failed to stop log_end_msg 1 ;; esac ;; *) echo "Usage: $SCRIPTNAME {start|stop|status|restart|force-reload}" >&2 exit 3 ;; esac
Notes
It has been brought to my attention via comments of this answer that this init script does not work with deluge's webui. Please look at the documentation at deluge's website for further information. The following is their script:
WebUI/New Script
#!/bin/sh
### BEGIN INIT INFO
# Provides:          deluge-daemon
# Short-Description: Daemonized version of deluge and webui.
# Description:       Starts the deluge daemon with the user specified in
#                    /etc/default/deluge-daemon.
### END INIT INFO
Author: Adolfo R. Brandes
Updated by: Jean-Philippe "Orax" Roemer
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin DESC="Deluge Daemon" NAME1="deluged" NAME2="deluge" DAEMON1=/usr/bin/deluged DAEMON1_ARGS="-d" # Consult man deluged for more options DAEMON2=/usr/bin/deluge-web DAEMON2_ARGS="" # Consult man deluge-web for more options PIDFILE1=/var/run/$NAME1.pid PIDFILE2=/var/run/$NAME2.pid UMASK=022 # Change this to 0 if running deluged as its own user PKGNAME=deluge-daemon SCRIPTNAME=/etc/init.d/$PKGNAME
[ -x "$DAEMON1" -a -x "$DAEMON2" ] || exit 0
[ -r /etc/default/$PKGNAME ] && . /etc/default/$PKGNAME
Depend on lsb-base (>= 3.0-6) to ensure that this file is present.
if [ -z "$RUN_AT_STARTUP" -o "$RUN_AT_STARTUP" != "YES" ] then log_warning_msg "Not starting $PKGNAME, edit /etc/default/$PKGNAME to start it." exit 0 fi
if [ -z "$DELUGED_USER" ] then log_warning_msg "Not starting $PKGNAME, DELUGED_USER not set in /etc/default/$PKGNAME." exit 0 fi
Function to verify if a pid is alive
is_alive() { pid=cat $1 > /dev/null 2>&1 kill -0 $pid > /dev/null 2>&1 return $? }
do_start() {
Return
is_alive $PIDFILE1 RETVAL1="$?"
if [ $RETVAL1 != 0 ]; then rm -f $PIDFILE1 start-stop-daemon --start --background --quiet --pidfile $PIDFILE1 --make-pidfile
--exec $DAEMON1 --chuid $DELUGED_USER --user $DELUGED_USER --umask $UMASK -- $DAEMON1_ARGS RETVAL1="$?" else is_alive $PIDFILE2 RETVAL2="$?" [ "$RETVAL2" = "0" -a "$RETVAL1" = "0" ] && return 1 fi
if [ $RETVAL2 != 0 ]; then sleep 2 rm -f $PIDFILE2 start-stop-daemon --start --background --quiet --pidfile $PIDFILE2 --make-pidfile
--exec $DAEMON2 --chuid $DELUGED_USER --user $DELUGED_USER --umask $UMASK -- $DAEMON2_ARGS RETVAL2="$?" fi [ "$RETVAL1" = "0" -a "$RETVAL2" = "0" ] || return 2 }
do_stop() {
Return
start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --user $DELUGED_USER --pidfile $PIDFILE2 RETVAL2="$?" start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --user $DELUGED_USER --pidfile $PIDFILE1 RETVAL1="$?" [ "$RETVAL1" = "2" -o "$RETVAL2" = "2" ] && return 2
rm -f $PIDFILE1 $PIDFILE2
[ "$RETVAL1" = "0" -a "$RETVAL2" = "0" ] && return 0 || return 1 }
case "$1" in start) [ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME1" do_start case "$?" in 0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;; 2) [ "$VERBOSE" != no ] && log_end_msg 1 ;; esac ;; stop) [ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME1" do_stop case "$?" in 0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;; 2) [ "$VERBOSE" != no ] && log_end_msg 1 ;; esac ;; restart|force-reload) log_daemon_msg "Restarting $DESC" "$NAME1" do_stop case "$?" in 0|1) do_start case "$?" in 0) log_end_msg 0 ;; 1) log_end_msg 1 ;; # Old process is still running ) log_end_msg 1 ;; # Failed to start esac ;; ) # Failed to stop log_end_msg 1 ;; esac ;; *) echo "Usage: $SCRIPTNAME {start|stop|restart|force-reload}" >&2 exit 3 ;; esac
earthmeLon
  • 1,414
Nope, deluge does not have init scripts in current debian, as well as in ubuntu and a bunch of other Linuxes. They have guides on creating such scripts though: http://dev.deluge-torrent.org/wiki/UserGuide/InitScript (and one especially for debian&ubuntu). It should not be that hard, but I switched to transmission because of this extra work.
Osman-pasha
  • 418
That seems to be an (old) outstanding issue: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=541138
You might try the version from Debian Expirimental, see:
http://wiki.debian.org/DebianExperimental and http://packages.debian.org/search?suite=experimental&searchon=names&keywords=deluged
AVee
  • 101
