I am currently running the latest Raspian Jessie on my Raspberry Pi 3 and I have attempted to use my Sony bluetooth headphones. I am able to pair and connect the headphones, but when I try to switch the audio source to them by right clicking on the audio icon it says, "Failed to connect to device-Could not connect to PulseAudio. Try to connect again."
I run the command bluetoothctl > info BB:BB:BB:BB:BB:BB (my bluetooth headphones) and it outputs the following:
Alias: MDR-XB950BT
Class: 0x240404
Icon: audio-card
Paired: yes
Trusted: yes
Blocked: no
Connected: yes
LegacyPairing: no
UUID: Headset (00001108-0000-1000-8000-00805f9b34fb)
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: Handsfree (0000111e-0000-1000-8000-00805f9b34fb)
Also, here is the link to the model of my headphones: MDR-XB950BT
Ghanima
  • 15,958
  • 65
Sam
  • 41
I have created a script that will set this up for you automatically. It is apart of another project but can used without the main project. Simply use the following commands
   git clone https://github.com/bareinhard/a2dp_bluetooth
   cd a2dp_bluetooth/a2dp_source
   ./configure
   # answer the one prompt it asks for and wait for the install to complete then reboot
from there you just need to pair, trust, and connect to your device. From then on every time you turn on your device it should pair to the Pi. If audio is playing when the device is turned on and connected the playing music a udev rule will then move the sink input to your connected device.
If you would like a deeper walkthrough of what is going on, I'd urge you to take a look at the answer I left here:
https://raspberrypi.stackexchange.com/a/76288/43610
Brett Reinhard
  • 456
This is a pretty old post but I will give my solution for it helped me with (2020-02-13-raspbian-buster-lite)
Edit the file /etc/dbus-1/system.d/bluetooth.conf
scroll down to the bottom of the file where you should see:
<policy context="default">
    <deny send_destination="org.bluez"/>
Change the "deny" to "allow"
I am using an UE-BOOM bluetooth device. Hope this helps
it_guy
  • 41
