I'm trying to stream some images form opencv using gstreamer and I got some issues with the pipeline. I'm new to gstreamer and opencv in general. I compiled opencv 3.2 with gstreamer for python3 on a raspberry pi 3. I have a little bash script that I use with raspivid
raspivid -fps 25 -h 720 -w 1080 -vf -n -t 0 -b 2000000 -o - | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! tcpserversink host=192.168.1.27 port=5000
I wanted to translate this pipeline in order to use it from opencv and feed it images that my algorithm manipulates. I did some research and figured that I can use videoWriter with appsrc instead of fdsrc but I get the following error
GStreamer Plugin: Embedded video playback halted; module appsrc0 reported: Internal data flow error.
The python script that I came up with is the following by the way import cv2
cap = cv2.VideoCapture(0)
# Define the codec and create VideoWriter object
fourcc = cv2.VideoWriter_fourcc(*'MJPG')
out = cv2.VideoWriter('appsrc  ! h264parse ! '
                      'rtph264pay config-interval=1 pt=96 ! '
                      'gdppay ! tcpserversink host=192.168.1.27 port=5000 ',
                      fourcc, 20.0, (640, 480))
while cap.isOpened():
    ret, frame = cap.read()
    if ret:
        frame = cv2.flip(frame, 0)
        # write the flipped frame
        out.write(frame)
        if cv2.waitKey(1) & 0xFF == ord('q'):
            break
    else:
        break
# Release everything if job is finished
cap.release()
out.release()
cv2.destroyAllWindows()
Are there any errors in the pipeline? I don't understand the error. I already have a Python client that can read from the bash pipeline and the results are pretty good from the latency perspective and consumed resources.
Quintin B
  • 689
WisdomPill
  • 142
Please add videoconvert after appsrc as you need to convert format of the video to display it on autovideosink or stream it using udpsink. It could be something like this:
video = cv2.VideoWriter('appsrc ! queue ! videoconvert ! video/x-raw ! omxh264enc ! video/x-h264 ! h264parse ! rtph264pay ! udpsink host=192.168.0.2 port=5000 sync=false',0,25.0,(640,480))
SlySven
  • 3,631
  • 46
mbed_geek
  • 36
