21
I followed this guide to emulate RPI on OSX via VirtualBox and it works. Now I'd like to simplify things a bit since this solution involves running debian in a virtual machine just to run qemu on top of.
I googled for guides on how to setup qemu straight on osx and found Matthew Yee-King's guide. I followed the instructions and all seems fine until the last part. When I launch qemu-system-arm I see the QEMU window appear but the application seems to freeze. After a while it appears as Not Responding in Activity Manager.
What am I missing ? How do I emulate RPI on OSX with QEMU ?
George Profenza
  • 651
  • 25
To set up an emulated environment of the Raspberry Pi software on OSX one will need:
  • A Cross-Compiling Tool for the CPU architecture of RPi. ( eg. ARM EABI Toolchain )
  • The RPi Kernel.
  • The RPi root filesystem.
  • The Emulator (QEMU).
  • The Cross-Compiling Tool for the ARM architecture.
Assuming one already have the latest Xcode and command line tools from Apple Developer and homebrew installed, then should install the dependencies:
brew install mpfr gmp libmpc libelf texinfo
Grab and compile the tool:
mkdir ~/rpi
mkdir ~/rpi/arm-cs-tools
git clone https://github.com/jsnyder/arm-eabi-toolchain.git
cd arm-eabi-toolchain
PREFIX=$HOME/rpi/arm-cs-tools make install-cross
make clean
echo “export PATH=$HOME/rpi/arm-cs-tools/bin:$PATH” » ~/.bash_profile
The RPi Kernel Compilation
mkdir ~/rpi/kernel
cd ~/rpi/kernel
git clone --depth=1 https://github.com/raspberrypi/linux.git
cd linux
Grab the config file and configure the kernel:
cp arch/arm/configs/bcmrpi_cutdown_defconfig .config
make ARCH=arm CROSS_COMPILE=~/rpi/arm-cs-tools/bin/arm-none-eabi- menuconfig
Save the configuration and let’s build the kernel afterwards. Note that the compilation should fail and complain about an <elf.h> inclusion in scripts/mod/mk_elfconfig. If it does, one must create the file:
sudo touch /usr/local/include/elf.h
Edit it and write the following:
#include <libelf.h>
#define R_386_NONE 0 #define R_386_32 1 #define R_386_PC32 2 #define R_ARM_NONE 0 #define R_ARM_PC24 1 #define R_ARM_ABS32 2 #define R_MIPS_NONE 0 #define R_MIPS_16 1 #define R_MIPS_32 2 #define R_MIPS_REL32 3 #define R_MIPS_26 4 #define R_MIPS_HI16 5 #define R_MIPS_LO16 6
and follow through the building process:
make ARCH=arm CROSS_COMPILE=~/rpi/arm-cs-tools/bin/arm-none-eabi- -k
The image file is created and located as arch/arm/boot/zImage.
The Emulator
Due to a bug of a white screen hanging QEMU if compiled with llvm one must install the package apple-gcc42 from the homebrew’s dupes repository.
brew install homebrew/dupes/apple-gcc42
And then compile and install qemu like:
brew install qemu —use-gcc
Now we’re left with all we need to start the RPi distribution so let’s start it like:
qemu-system-arm -M versatilepb -cpu arm1176 -hda debian6-19-04-2012.img -kernel zImage -append “root=/dev/sda2” -serial stdio -usbdevice tablet
As refered on mluis's website.
mluis
  • 316
There is a ready to run paid option that runs over QEMU: https://snorfi.us/raspiemu/
If you don't want to pay for it you can also download the alpha version in https://sourceforge.net/projects/raspberrypiemulator/
Felipe Plets
  • 131
It looks like the 'configure the kernel' step needs a bit more. Note that
should be one of the files in that directory like arm-none-eabi-ar or arm-none-eabi-as etc...
Brick
  • 1,375
