In the datasheet, the maximum clock frequency (when the ADC is powered with maximum voltage of 5V) is 3.6 MHz. Each read takes about 24 clock cycles which gives us a maximum sampling rate of about 150 KSPS. However, I have a couple of questions:
1) Why is it that the ADC is advertised to be a 200 ksps ADC when the theoretical maximum is about 150 KSPS?
2) Is the calculation that I have done correct?
Thank you!
You have made the assumption that 24 clocks are required. A quick look at the datasheet suggests 18 clocks are required per cycle. This gives a figure of 3600000 / 18 = 200000
The faulty assumption is that all devices require transfers in multiples of 8 bits.
joan
  • 71,852
  • 76
  • 108
