Ordered a Raspberry Pi 3B and sensehat a couple of days ago, they've arrived and I have set it all up as per the instructions.
I've run sudo apt-get update,sudo apt-get upgrade -y and sudo reboot
but then upon trying to run the example code:
from sense_hat import SenseHat
sense = SenseHat()
sense.show_message("Hello world !!")
I get the following error:
  File "/home/pi/Desktop/testing sensehat.py", line 2, in <module>
    sense = SenseHat()
  File "/usr/lib/python2.7/dist-packages/sense_hat/sense_hat.py", line 39, in __init__
    raise OSError('Cannot detect %s device' % self.SENSE_HAT_FB_NAME)
OSError: Cannot detect RPi-Sense FB device
Furthermore, the SenseHat LED display continues to show the rainbow even after the login screen.
I've had a bit of a look around and done some diagnostics.
sudo dmesg returned:
[    4.764770] rpi-sense 1-0046: Read from reg 240 failed
[    4.764826] rpi-sense: probe of 1-0046 failed with error -22
which I figure is probably the reason I am having issues, but I don't know what that message means, nor how to go about rectifying the issue.
Any help would be greatly appreciated.
Thanks in advance!
Josh
I've just bought the same hardware and had the exact same issue.
After reading what felt like hours of webpages (not not understanding 99% of it), adding:
dtoverlay=rpi-sense
to the bottom of /boot/config.txt has resolved the issue.
Travis
