I'm trying to power the onboard LEDs of my Raspberry Pi 3 Model B+ using this tutorial as follows:
Firstly you need to disable the usual triggers for the built-in LEDs. This can be done from the terminal with the following commands:
$ echo none | sudo tee /sys/class/leds/led0/trigger
$ echo gpio | sudo tee /sys/class/leds/led1/trigger
Now you can control the LEDs with gpiozero like so:
from gpiozero import LED
from signal import pause
power = LED(35) # /sys/class/leds/led1
activity = LED(47) # /sys/class/leds/led0
activity.blink()
power.blink()
pause()
when I run the above code stored in onboard_led.py, I get this error: /usr/lib/python2.7/dist-packages/gpiozero/pins/rpigpio.py:95: PinNonPhysical: no physical pins exist for GPIO35 'no physical pins exist for GPIO%d' % number)) /usr/lib/python2.7/dist-packages/gpiozero/pins/rpigpio.py:95: PinNonPhysical: no physical pins exist for GPIO47 'no physical pins exist for GPIO%d' % number))
Is the documentation out of date, my pins don't exist, or the pins have changed?
KhoPhi
  • 143
From a note near the very bottom of the documentation you linked to:
On the Pi 3B the LEDs are controlled by a GPIO expander which is not accessible from gpiozero (yet).
stevieb
  • 1,456
The following Python code seems to work well for me to control the onboard LEDs on a Pi 3B running Raspbian GNU/Linux 9 (stretch). Save it to led.py, then you can call it from your main program with import led then led.control("red", "flash"), for example.
If you don't want to use Python, you can issue the commands directly in a shell. For example, to turn the red LED off, echo 0 | sudo tee /sys/class/leds/led1/brightness should do the trick.
import os
green_led = "/sys/class/leds/led0"
red_led = "/sys/class/leds/led1"
green_led_reset_trigger = "mmc0"
red_led_reset_trigger = "input"
def control(led_colour, state):
    if led_colour == "green":
        device = green_led
    elif led_colour == "red":
        device = red_led
    else:
        return
    if  state == "on":
        os.system("echo none | tee " + device + "/trigger >> /dev/null")
        os.system("echo 1 | tee " + device + "/brightness >> /dev/null")
    elif state == "off":
        os.system("echo 0 | tee " + device + "/brightness >> /dev/null")
    elif state == "flash":
        os.system("echo timer | tee " + device + "/trigger >> /dev/null")
    elif state == "reset":
        if device == green_led:
            trigger = green_led_reset_trigger
        elif device == red_led:
            trigger = red_led_reset_trigger
        os.system("echo " + trigger + " | tee " + device + "/trigger >> /dev/null")
    else:
        return
Issues:
  • The Pi can be very slow to change the LED state. If you call this function more than once a second, it sometimes misses the state change.
  • To avoid having to run the code as root, you'll need to change the default permissions on the LEDs. You can automate this by placing the following script in /etc/init.d/led-control:
    #! /bin/sh
    # /etc/init.d/led-control
    ### BEGIN INIT INFO
    # Provides:          led-control
    # Required-Start:    $remote_fs $syslog
    # Required-Stop:     $remote_fs $syslog
    # Default-Start:     2 3 4 5
    # Default-Stop:      0 1 6
    # Short-Description: Change permissions on Raspberry Pi LEDs to allow them to be switched on and off
    # Description:       Raspberry Pi status LEDs are normally only controlled by root. This script enables them to be controlled by regular users.
    ### END INIT INFO
    # If you want a command to always run, put it here
    # Carry out specific functions when asked to by the system
    case "$1" in
      start)
        echo "Enabling led-control"
        # Raspberry Pi status LED
        /bin/chmod 666 /sys/class/leds/led0/trigger
        /bin/chmod 666 /sys/class/leds/led0/brightness
        # Raspberry Pi power LED
        /bin/chmod 666 /sys/class/leds/led1/trigger
        /bin/chmod 666 /sys/class/leds/led1/brightness
      stop)
        echo "Disabling led-control"
        # kill application you want to stop
        /bin/chmod 644 /sys/class/leds/led0/trigger
        /bin/chmod 644 /sys/class/leds/led1/trigger
        /bin/chmod 644 /sys/class/leds/led0/brightness
        /bin/chmod 644 /sys/class/leds/led1/brightness
        echo "Usage: /etc/init.d/led-control {start|stop}"
        exit 1
    esac
    exit 0
    Install the startup script with sudo update-rc.d led-control defaults so it runs on boot. Activate it with sudo /etc/init.d/led-control start
clanger9
This answer worked for me on Raspberry Pi 3B running Raspbian Lite Stretch to blink the green activity light. (I did not attempt to control the red power light.) It involves an obscure command to write to the mailbox interface for the light.
alias led_on="/opt/vc/bin/vcmailbox 0x00038041 8 8 130 1 >/dev/null"
alias led_off="/opt/vc/bin/vcmailbox 0x00038041 8 8 130 0 >/dev/null"
while [ 1 ]; do led_on; sleep 1; led_off; sleep 1; done
To disable the automatic blinking on SD card activity, you must write to the LED's trigger file.
sudo sh -c "echo none > /sys/class/leds/led0/trigger"
The trigger is reset on reboot. You can add the above command to /etc/rc.local before the exit 0 line to disable the SD card activity indicator at startup.
I have not seen any evidence that the pi3-act-led overlay can be used.
rgov
  • 223
While it is correct that the onboard LEDs are on an expander, they are already accessible for quite some time. See this github issue 1363 from 2016. According to its documentation, the pi3-act-led overlay "changes the GPIO controller back to the standard one and restores the dtparams".
TheDiveO
  • 1,591
