My .asoundrc file gets modified every boot. If I delete it, a new appears at reboot:
pcm.!default {
        type hw
        card 0
ctl.!default {
        type hw
        card 0
If I make changes that differ from these, eg set type plug, then the above entry is appended to the file, effectively removing my changes. What is going on?!
Edit: If I wait 5 seconds after launching PIXEL at boot, then overwrite .asoundrc with this:
pcm.!default {
        type plug
        slave {
            pcm "hw:0,0"
ctl.!default {
        type hw
        card 0
Then it works like I want. Is something in PIXEL smoking my file? How can I disable that?
NateS
  • 139
The thing that over write your user ALSA config is most likely the lxpanel. Within the lxpanel there are several applets (the clickable icons). The lxplug-volume applet has proven to be one of the culprits as can be seen in the code of volumealsabt.c.
Remove the Volume Applet by left clicking on the panel and selecting it, and then delete.
Check for updates to lxpanel, by running the following:
sudo apt-get update
apt list --upgradable
# Then check if the list contain any of these:
lxpanel
lxinput
lxpanel-data
lxplug-bluetooth
lxplug-ejecter
lxplug-network
lxplug-ptbatt
lxplug-volume
# If yes, then use sudo apt-get install <name>
If this doesn't resolve it, please see my other post.
not2qubit
  • 1,439
