I have being follow the steps from Amazon Officials pages to connect the Raspberry Pi to AWS IoT cloud, that's working fine but my main concern is to how to write a code to start interfacing with sensors? Like Digital Inputs and Outputs.
Do you know any resource that show you how to start to interface with AWS IoT in such a way to read inputs from the RPi? How to send commands to the make HIGH a led?
I think I may be very directly with my question but I wanna see if you know some methods to start to work with the AWS IoT cloud?
Thanks
fabocode
Due to Raspbian support Python 2&3, you can check online documents about AWS SDK for Python to start your coding.
http://docs.aws.amazon.com/iot/latest/apireference/iot-api.pdf
https://github.com/aws/aws-iot-device-sdk-python/blob/master/README.rst
But for beginners, I suggest that before you start to approach the Amazon AWS, you should try on
CloudMQTT
and make a simple project like :
"turn the LED on/off"
or
"turn the LED on if the temperature is above 30 Celcius degrees" (which use Arduino UNO to support you)
Binh Nguyen
  • 159
