Simple question: how do you turn off the d*mn screen saver in Raspbian for Pi 3 Model B? It keeps popping up even if I leave Chromium looping a video in Kiosk mode. I tried the solution from this answer, but it does nothing to stop the screensaver from showing.
Asked
Active
Viewed 1.8k times
You should try using xscreensaver. You can easily disable screen saver using xscreensaver-demo, which will prompt a simple GUI config. In the Display Modes tab, you should see a drop-down list named Mode. From there select Disable Screen Saver and that should do the trick.
You don't have to use the graphical interface, here is a link to the manual if you are interested in looking at specific terminal commands etc: https://www.jwz.org/xscreensaver/man1.html
LecauseAndThePi
- 371
- 5
- 14
