Disclaimer: My knowledge is fairly limited when it comes to electronics.
I want to connect an external PSU to the 2/4 GPIO pins. Link to PSU
I didn't know a barrel to microUSB adaptor exist and I cut off the connector, so I now have 2 exposed wires coming out of the PSU.
I want to know what the best way would be to physically connect these to the pins?
I wanted to use Dupont connectors but the wires are 16AWG and I'm not sure they will fit (and I don't have any around to try)
Are there any other suggested ways to connect directly to the pins or to "break-out" the pins just for this purpose?
Thanks!
Note: I know that connecting directly to the GPIO will bypass the builtin protection mechanisms. The PSU is 5V regulated (5%). I am not sure if this counts as a comprehensive test but I measured it with the MinMax function of my Fluke Min==Max==Avg==5.135V
Bex
  • 2,929
  • 26
  • 34
Itsik
  • 101
I would use a jumper wire with a female end. Just cut it in half and solder or twist the +5v power wire to the jumper wire and insulate with tape. Ditto for the ground wire.
joan
  • 71,852
  • 76
  • 108
This is not really a Pi question, however I feel obliged to comment.
There is nothing wrong with connecting to the power pins on the header, see Raspberry Pi Power Limitations HOWEVER I would not use Dupont connectors.
You will be connecting these hundreds of times. It is only a matter of time before you do it wrong. Use of an unpolarised connector is inherently risky.
When I need to use an external supply I usually do one of 2 things;
  1. Obtain a USB to microUSB adapter (these are readily available on ebay) and solder a normal male USB cable to the PSU, TRIPLE checking polarity before connecting to the Pi.
  2. Use a female USB connector wired to the PSU and a normal microUSB power cable.
