Whenever I try to install SimpleCV, I always get this error message.
  File "/usr/bin/pip", line 9, in <module>
    load_entry_point('pip==1.5.6', 'console_scripts', 'pip')()
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 356, in load_entry_point
    return get_distribution(dist).load_entry_point(group, name)
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2476, in load_entry_point
    return ep.load()
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2190, in load
    ['__name__'])
  File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line 74, in <module>
    from pip.vcs import git, mercurial, subversion, bazaar  # noqa
  File "/usr/lib/python2.7/dist-packages/pip/vcs/mercurial.py", line 9, in <module>
    from pip.download import path_to_url
  File "/usr/lib/python2.7/dist-packages/pip/download.py", line 25, in <module>
    from requests.compat import IncompleteRead
ImportError: cannot import name IncompleteRead
What went wrong and can you give me the code to install SimpleCV properly?
Arun
  • 261
To install SimpleCV, first install the prerequisite packages using these commands:
$ sudo apt-get update
$ sudo apt-get install ipython python-opencv python-scipy
$ sudo apt-get install python-numpy python-setuptools python-pip
$ sudo pip install svgwrite
Then install SimpleCV itself using the command:
$ sudo pip install https://github.com/sightmachine/SimpleCV/zipball/master
If this command not working you can alternatively use this:
$sudo pip install https://github.com/ingenuitas/SimpleCV/zipball/master
Once installation is complete, you can check that everything worked by running this command(You can also check is simpleCV installed on your Pi before using this command):
$ simplecv
 SimpleCV 1.3.0 [interactive shell] - http://simplecv.org
Commands:
 "exit()" or press "Ctrl+ D" to exit the shell
 "clear()" to clear the shell screen
 "tutorial()" to begin the SimpleCV interactive tutorial
 "example()" gives a list of examples you can run
 "forums()" will launch a web browser for the help forums
 "walkthrough()" will launch a web browser with a walkthrough
This will open the SimpleCV console. This is a Python console, with extra features for SimpleCV. However installation of simpleCV already asked on Stack Exchange. This may also helpful for you. If you are installed OpenCV before that may be a reason for failure of simpleCV installation. Alternate method for installing simpleCV is discussed on this article. But I didn't used this method yet. Since first method was worked for me.
Arun
  • 261
