I am trying to debug a bare metal application using openocd (seggers does not provide support for the cortex a-53 so jlink won't work). I installed openocd following this set of instructions.
However when I call the command:
openocd -f interface/jlink.cfg -f /target/rpi3.cfg
I get the following errors:
Error: JTAG scan chain interrogation failed: all zeroes │
Error: Check JTAG interface, timings, target power, etc. │
Error: Trying to use configured scan chain anyway... │
Error: rpi3.dap: IR capture error; saw 0x00 not 0x01 │
Warn : Bypassing JTAG setup events due to errors │
Warn : Invalid ACK 0 in JTAG-DP transaction
The complete output is:
Open On-Chip Debugger 0.9.0-dev-gb796a58 (2017-06-05-20:22) │nc localhost 4444
Licensed under GNU GPL v2 │��������Open On-Chip Debugger
For bug reports, read │> jtag init
http://openocd.sourceforge.net/doc/doxygen/bugs.html │jtag init
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain connect_deassert│JTAG scan chain interrogation failed: all zeroes
_srst │Check JTAG interface, timings, target power, etc.
adapter speed: 1000 kHz │Trying to use configured scan chain anyway...
jtag_ntrst_delay: 500 │rpi3.dap: IR capture error; saw 0x00 not 0x01
Info : J-Link ARM V8 compiled Nov 28 2014 13:44:46 │Bypassing JTAG setup events due to errors
Info : J-Link caps 0xb9ff7bbf │>
Info : J-Link hw version 80000 ├──────────────────────────────────────────────────────────────────────────────────────
Info : J-Link hw type J-Link │4.3:*****@*****-******:/usr/local/share/openocd/scripts/interface$
Info : J-Link max mem block 9224 │
Info : J-Link configuration │
Info : USB-Address: 0x0 │
Info : Kickstart power on JTAG-pin 19: 0xffffffff │
Info : Vref = 3.287 TCK = 1 TDI = 0 TDO = 0 TMS = 0 SRST = 1 TRST = 1 │
Info : J-Link JTAG Interface ready │
Info : clock speed 1000 kHz │
I have searched for a solution online for days now but everything I have tried has been so far unsuccessful. If anyone could either tell me what is causing this error, or give me an alternative way to use gdb to debug my embedded program I'd be very grateful.
