I am looking to start a small company that sells Pi's predefined to fit my customer's needs. My question is:
Is there a site where I can order custom raspberry Pis in bulk with my code already on them? This way I don't have to add my components and code to each unit I sell.
If not, would any of you recommend another device that has this type of support, other than the Pi?
Darth Vader
  • 4,218
  • 47
  • 70
now_world
  • 163
The manufacture of Raspberry Pi's as far as I am aware is by Element14/Premier Farnell. Originally they were made in China but are now produced in the UK, which is fitting, given the Foundation is a British organisation. You can read more about that here.
In terms of a Pi made for commercial use Element14 have an exclusive Raspberry Pi customization area. This would allow you to order customized Pi's in bulk orders. I've not really looked into this too much as I haven't had the need to bulk order Pi's. If you contact Element14 with your request they might be able to find a solution for you.
You might also be interested in the Compute Module, which fits in a DDR2 SODIMM connector. This is aimed at people looking to produce custom PCBs. You could probably bulk order them and try to find an electronics company to build a board with your required components.
As to another device with extensive customization support, well that really would depend on your needs. It's also a question that wouldn't be on-topic here as it's not related to the Pi and is more of a business operations question anyway.
Darth Vader
  • 4,218
  • 47
  • 70
You haven't mentioned any hardware customisation, so assuming the hardware is standard and it's just your code you need to copy, you could build an image and use an SD duplication service like this (first hit on google) http://www.diskcopy.com/product-info/custom-sd-cards
Then just ship 'stock' raspberry Pi's with your SD cards.
JeffUK
  • 181
Yes, pretty much any reseller would be happy to quote you for this. Element14's custom hardware supply cuts in at 5000 units, which might be a bit much for your needs. But if it's a customized distribution in a particular case with perhaps a hardware add-on, it's all down to whether you can agree a price that the reseller's able to work with.
As regards other boards, that's purely a technical and commercial decision on your part. The NextThing C.H.I.P. Pro, the commercial BeagleBones or any of the 96Boards might do it for you.
scruss
  • 9,117
  • 25
  • 36
