15
Recently, after I ran apt-get upgrade, my Pi 3 running Raspbian Jessie started using a random MAC address on eth0 after every reboot. I'm pretty sure this has something to do with the upgrade since I haven't messed with my network config in a long time.
My current /etc/network/interfaces file is as follows:
auto lo
iface lo inet loopback
iface eth0 inet auto
I tried appending the following line to it but to no avail:
    hwaddress ether xx:xx:xx:xx:xx:xx
As some people suggested in this thread I checked the serial no. in /proc/cpuinfo and it matches the static MAC address the Pi previously used.
Is there any way I could go back to having a static MAC address on my Pi?
mohak
  • 273
Seems like it's a feature of network-manager...
I installed networkmanager and random mac shows up, so I uninstalled it and problems solved:
sudo apt-get remove network-manager
甘礼良
  • 151
Open a Terminal window and run:
sudo nano /boot/cmdline.txt
If in the file you see any mention of a MAC address remove it from the file. Then exit the file with saving.
To set a fixed MAC address run:
sudo nano /boot/config.txt
Add the following line if it does not already exist:
smsc95xx.macaddr=B8:AA:BC:DE:F0:12
Again, exit the file with saving. B8:AA:BC:DE:F0:12 is the MAC address.
Darth Vader
  • 4,218
  • 47
  • 70
As @leanne said in the comments, you can use this command to keep network-manager (needed for some features) but disable MAC Address Randomization:
printf "[connection]\nwifi.mac-address-randomization=1\n\n[device]\nwifi.scan-rand-mac-address=no\n" | sudo tee /etc/NetworkManager/conf.d/100-disable-wifi-mac-randomization.conf
Dan Chaltiel
  • 215
