I am looking for a patch of WebIOPi for the Pi Zero W.
I will appreciate you very much, if you could suggest where I can find it on the internet.
WebIOPi's version is 0.7.1.
I could find some patches for the Pi 3 and 2 but I can't find any for the Pi Zero W.
Darth Vader
  • 4,218
  • 47
  • 70
Tam
If you have an old version installed you will need to run the following:
sudo dpkg --purge python2-webiopi
sudo dpkg --purge python3-webiopi
find /usr | grep -i webiopi  | sort > ~/webiopi.old.files
tar cjvf ~/webiopi.old.tbz --files-from ~/webiopi.old.files
cat ~/webiopi.old.files | sort -r | sed -e 's/^/sudo rm -f /;' |  sh 2>/dev/null
cat ~/webiopi.old.files | sort -r | sed -e 's/^/sudo rmdir /;' | sh 2>/dev/nul
Then to install the working version run:
git clone https://github.com/thortex/rpi3-webiopi.git
cd rpi3-webiopi
You will need to install some Debian package management development files:
cd dev
./01_setup-required-packages.sh
Then install Python setup tools and and development files:
./03_install_python_dev.sh
Next run this to build the package:
./10_make_deb.sh
Finally install WebIOPi+ with:
sudo dpkg -i ~/build.webiopi/python2-webiopi*.deb
sudo dpkg -i ~/build.webiopi/python3-webiopi*.deb
sudo webiopi-select-python 2
sudo systemctl daemon-reload
sudo systemctl restart webiopi
To install WebIOPi+ for Python 3 run:
webiopi-select-python 3
To to start/stop/restart WebIOPi daemon:
sudo /etc/init.d/webiopi restart
This WebIOPi+ is based off the original WebIOPi version however it has been designed to work with the Pi Zero.
For more information here is the official GitHub page.
Darth Vader
  • 4,218
  • 47
  • 70
