I have this keyboard: http://trust.com/products/product.aspx?artnr=17603 and i cant configure it with Raspbian. I run rasp-config and went to configure_keyboard, selected a generic 105-key keyboard and set the language to Portuguese (my language) and it is all messy!
Help is appreciated
Asked
Active
Viewed 5,107 times
pasadinhas
- 153
- 1
- 2
- 7
Check your /etc/default/keyboard for your layout.
cat /etc/default/keyboard | grep LAYOUT
If it's anything other than your language code, let's change it. We'll have to do that as root, so:
sudo nano /etc/default/keyboard
and change the value to what you need it to be. I use dvorak, so if I were on Debian mine would look like:
XKBLAYOUT="dvorak"
Yours will just be your language code, though. Just to make sure, also, it'd probably be good measure to check your locale. Can you also check the result of:
env | grep LANG
coxley
- 198
- 5
