I just got a Raspberry pi 3 with a WD usb external pi hardrive. The hardrive comes with a bootberry sd card with really confusing and contradictory instructions that installed (old outdated versions of everything) but was a pain to setup. I think I just bricked the OSes I had on it by changing the names* in the bootberry window, or something, anyways two out of the three will no longer boot.
I have way more experience with noobs, and have never been disappointed. Can noobs work with external hardrives? How would I do that? I want rasbian, some elec, and some emulator OS. I would like rasbian, elec, and the emulator OS to be able to share files if at all possible.
*The list of OSes had their version number, since the updates were extensive I though their were probably outdated, so clicked rename to just rename them to their base name, sans version number. You think their would be some warning that I was changing not only the menu designation, but key features of the OSes that they depended on.
Jonathon
  • 127
I have a NOOBS system card with Raspbian on the hard disk.
pi@RPi0:~ $ lsblk
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sdb            8:16   0 931.5G  0 disk
└─sdb1         8:17   0 931.5G  0 part /
sda            8:0    1   7.3G  0 disk
└─sda1         8:1    1   7.3G  0 part /media/pi/boot
mmcblk0      179:0    0  29.3G  0 disk
├─mmcblk0p12 179:12   0    66M  0 part /media/pi/boot1
├─mmcblk0p2  179:2    0     1K  0 part
├─mmcblk0p10 179:10   0    66M  0 part /boot
├─mmcblk0p9  179:9    0   6.9G  0 part /media/pi/897d2cca-c97f-4ee8-ba6d-c4c2cff
├─mmcblk0p7  179:7    0   1.9G  0 part
├─mmcblk0p5  179:5    0    32M  0 part /media/pi/SETTINGS
├─mmcblk0p13 179:13   0   7.5G  0 part /media/pi/root0
├─mmcblk0p11 179:11   0  10.2G  0 part /media/pi/root1
├─mmcblk0p1  179:1    0   1.4G  0 part
├─mmcblk0p8  179:8    0   512M  0 part /media/pi/6801-27D7
├─mmcblk0p6  179:6    0    47M  0 part /media/pi/RISC_OS_Boo
└─mmcblk0p14 179:14   0   512M  0 part /media/pi/data
Understand how NOOBS works is the key to using the hard disk. mmcblk0p1 is a FAT (FAT16) partition for NOOBS to boot first. In my case mmcblk0p10 is the Raspbian boot partition, also FAT (FAT32), that is booted second to load the root partition on the hard disk. The mmcblk0p11 is the installed root for Raspbian that I copied to the hard disk and changed the /boot/cmdline.txt file where root=PARTUUID=cf93980c-01, which is the partition on the hard disk. All of the different OS boot partitions are of type FAT. NOOBS makes all the root partitions of type Linux (ext4), check with sudo fdisk -l command. You could format the hard disk in many different ways to fit your needs. To share data with the different OS, make a data partition on the hard disk, make filesystem (mkfs.ext4 -L data /dev/sda1) - if /dev/sda1 is the data partition just created, and mount it in each OS /etc/fstab. You may wish to see How can I backup my whole SD to an img file usable with Etcher to restore later? for more ideas.
bstipe
  • 574
NOOBS does not currently allow for installing to and booting from an external drive. Berryboot (what the drive came with) is the only way that I know of to achieve this with the pi. Note that Berryboot allows you to install systems from the internet much like NOOBs does.
Note that NOOBS can work with USB drives on a pi3 natively if you enable USB boot in the OTP bits from a working raspbian SD card and the program_otp command line.
As for the installed OSs being outdated and requiring massive updates at first boot; that's to be expected from anything that isn't an online install. Offline install packages can't be updated without plugging them into an online system, so it makes sense to just let the system upgrade itself at first boot (or in the case of debian-installer, let you download newer packages at install-time)
BaconWaifu
  • 133
