i just want to supply power for other devices which uses 5 v dc from the raspberry pi by cutting and soldering the wires and also i want to connect all the USB ports with mouse keyboard WI-FI dongle and also i would like to connect my camera module to raspberry pi.
here my doubt is the is too much load on raspberry pi will that effect my pi
pavan
You can simply use an USB hub for something like that. This will not affect your raspberry pi but a lot of power shall be consumed. So do not forget to use a power supply with 5V 3A of minimum power supply. You do not need to solder anything. Pi is a very very delicate electronics board. Be careful before doing soldering.
Sohan Arafat
  • 1,852
  • 43
If your setup will allow, please use a powered usb hub. The Pi will push the wifi dongle and k+m easy. I've never hooked up a camera but I would image that the pi is getting close to it's max power draw with all of that plugged in. It would be helpful to just add the powered usb hub so that the Pi is not in danger of losing power when operating. Like mentioned before.. cutting wires and soldering should be last resort!
HUNN3R
Indeed, too much power consumption may affect rpi performance, and could even may damage the SD card is the rpi is shutting down while writing on it, or worst, damage internal fuse.
2 way to estimate :
1 ) Theoric way : count how much current you will take, and compare to what the rpi can provide. (1.2A on USB, from 16 mA from an individual 3.3V GPIO or more than 50 mA from the GPIO as a whole, but may vary with your rpi version)
2 ) Empiric way : Try to add more and more devices, until you see your rasberry producing smoke and fire.
I strongly recommend the first approach, as it's less risky for your hardware :)
goobering
  • 10,750
  • 40
  • 64
Technico.top
  • 1,426
