I bought my raspberry pi 3 model B 4 months back. It was working perfectly but one day, when I was working on pi, all of a sudden, it stopped working. After that day, when I am trying to power it up again, none of the red and green leds are blinking even for a second. Also, the central ic starts getting hot immediately. Has anyone faced a similar problem and came up with a solution to it? Also, since it's been just 4 months that I bought pi from amazon.in, will I be able to replace the product as it is still in the 1 year warranty period? Any suggestions are welcomed.
TIA
Bansari
  • 41
The IC getting hot is a usual sing of electrical damage. It's likely that you inadvertently connected some pins/pads that shouldn't be connected while working on your Pi and that killed it. Make sure you always power down the device when you connect/disconnect something except USB which explicitly supports hot-plugging.
Normally, you are not entitled to a free repair/replacement if you damaged the product yourself. However, unless there are visible traces of damage (typically that includes traces of water and physically broken parts), the manufacturer may not be able to prove that the damage was inflicted by you (and perhaps it wasn't), so they are likely to agree to replace it under warranty.
I'm not familiar with policies of amazon.in, but AFAIK Amazon handles returns during a 30-day period, after which you'll have to follow the return procedure defined by the seller. Such policies are available on the seller's page on Amazon.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
Trying another power cable, or adding a fan makes no sense when there is no response from the LED's. You must have a serious electrical problem and in that case I would recommend you to send your Pi back to the supplier.
Darth Vader
  • 4,218
  • 47
  • 70
Belekz
  • 158
If there is no response from the LEDs, the Pi is very likely fried. Returning it to your supplier for an exchange would be the best option.
Hmmm, there is no try.
I would put money on the fact that you were doing some wiring to the Pi and got something wrong!
Next time, double check your wiring. Then, check it again.
Don't do wiring when the Pi has power connected, even if shut-down!
I've been there and done that... twice (but shhhhh, don't tell anyone!)
electron1979
  • 121
