We're trying (unsuccessfully) to attach a UART bluetooth SoC to the Raspberry Pi 3 Compute Module.
The bluetooth SoC is a based off a Nordic nRF51. It's running project Zephyr RTOS hci_uart sample. Only changes made to this sample is: pins used for comms and added a blinking LED to assure CPU is running.
What have been done so far and it works:
  • on raspi-config removed the SSH over UART
  • added to /boot/config.txt dtparam=audio=off start_x=0 enable_uart=1 gpu_mem=16
  • bluez 5.43 compiled from source and installed fine. Check with any of the bluez tools with -v (also tried on bluez 5.44 with same results)
  • monitor the bluetooth sudo btmon
  • attach bluetooth module to system btattach -B /dev/ttyAMA0 -S 115200 -P h4
  • set beacon address, power on and scan for devices sudo btmgmt --index 0 static-addr ... something.... power on find -l
  • calling hciconfig we can see transmitted and received bytes between Pi and BT-SoC without issues.
What is missing: bluetoothctl Any attempt to use bluetoothctl informs that we have no controller.
bluetoothctl
[bluetooth]# list
[bluetooth]# agent on
Agent registered
[bluetooth]# default-agent
Default agent request successful
[bluetooth]# list
[bluetooth]# show
No default controller available
Further digging I've found that hciuart.service does not execute (as it would normally do on a Raspberry Pi 3:
pi@raspberrypi:~ $ systemctl status hciuart.service
● hciuart.service - Configure Bluetooth Modems connected by UART
   Loaded: loaded (/lib/systemd/system/hciuart.service; enabled)
   Active: inactive (dead)
           start condition failed at Tue 2017-05-23 09:44:13 CEST; 1s ago
           ConditionPathIsDirectory=/proc/device-tree/soc/gpio@7e200000/bt_pins was not met
pi@raspberrypi:~ $ cat /lib/systemd/system/hciuart.service
[Unit]
Description=Configure Bluetooth Modems connected by UART
Before=bluetooth.service
After=dev-serial1.device
[Service]
Type=forking
ExecStart=/usr/bin/btuart
[Install]
WantedBy=multi-user.target
It points that /proc/device-tree/soc/gpio@7e200000/bt_pins doesn't exist, and indeed it doesn't. I've tried to directly execute the binary from the service and got the following error message:
pi@raspberrypi:~ $ sudo /usr/bin/btuart
Can't open serial port: No such file or directory
Can't initialize device: No such file or directory
Doing the same tests using a USB serial connection to my Linux PC it works. Bluetoothctl have controller and it sees/communicates with the BT SoC
So my questions: - Why there is not bluetooth controller? how do I add/enable one? - Is it because of the hciuart.service? How do I enable it? - Is it because of the gpio@7e200000/bt_pins? How do I add, enable them?
Thanks a lot for any help
Budius
  • 141
Raspberry Pi 3B has Bluetooth disabled by default. If the Bluetooth is disabled, hcuiart service will fail to start and bluetoothctl will throw an error saying No default controller available
To turn on the Bluetooth, comment following line from
/boot/config.txt
dtoverlay=pi3-disable-bt
Reboot the Pi after saving the changes and the error should be gone.
Purush Pawar
  • 111
