23
I am using a Raspberry Pi 2, running Debian Jessie, and I have a problem with my Wi-Fi connection, after setting my /etc/network/interfaces:
    # uncomment the next 4 lines and set the correct wpa-ssid (network ssid) and
    auto lo
    iface lo inet loopback
    iface eth0 inet manual
    allow-hotplug wlan0
    iface wlan0 inet manual
and wpa_supplicant.conf:
ctrl_interface=/var/run/wpa_supplicant
network={
    ssid="Abass"
    psk="AMSH19691977"
then running wpa_cli reconfigure. I get the error, Failed to connect to non-global ctrl_ifname: (null) error: No such file or directory so need help. How can I resolve this?
Aurora0001
  • 6,357
  • 25
  • 39
Balsam Qassem
  • 359
8 Answers8
14
This worked for me
sudo nano /etc/network/interfaces
and add the following lines
auto wlan0
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
file looks like this
country=GB
update_config=1
network={
ssid="your ssid"
psk="your wifi password"
source https://www.domoticz.com/forum/viewtopic.php?t=10930
Anders B
  • 241
I have a cluster of 12+ RPis that I am initializing headlessly. The same exact image works on some and fails on others with the message:
Failed to connect to non-global ctrl_ifname: wlan0  error: No such file or directory
This is how I'm doing the wifi config:
#### Wifi Setup (WPA Supplicant)
##  Replaces the magic of https://github.com/RPi-Distro/raspberrypi-net-mods/blob/master/debian/raspberrypi-net-mods.service
##  See: https://www.raspberrypi.org/documentation/configuration/wireless/wireless-cli.md
cat > /etc/wpa_supplicant/wpa_supplicant.conf << EOF
update_config=1
country=US
network={
    ssid="wifi name goes here"
    psk="password goes here"
EOF
chmod 600 /etc/wpa_supplicant/wpa_supplicant.conf
wpa_cli -i wlan0 reconfigure
Since it was the last line that was giving the error, I replace it with this:
until wpa_cli -i wlan0 reconfigure; do
  echo "Failed to reconfigure wlan0 with wpa_cli."
  echo "Restarting dhcpcd with systemctl."
  systemctl restart dhcpcd
done
I've never had it loop through more than once, but I put the until there just in case it didn't respond the first time. But, that comes with the risk of never escaping. For my need, I don't want the script to continue without an internet connection. You can decide what works for you. A single pass implementation might look like this:
wpa_cli -i wlan0 reconfigure || ( systemctl restart dhcpcd; wpa_cli -i wlan0 reconfigure; )
Bruno Bronosky
  • 1,540
I ran into this problem when I ditched dhcpcd and chose systemd-networkd as network manager.
First, check how the wpa_supplicant service is launched by sudo systemctl status, if it indicates
/sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
, then you got the problem.
The wpa_supplicant service requires interface and drivers to run properly. This is how dhcpcd launches wpa_supplicant:
wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0-Dnl80211,wext
See the -i and -D options? Now you may shutdown your default blank wpa_supplicant service using sudo systemctl stop unit and launch a new one with these 2 options to see whether you still get the error and everything falls back to normal.
Since there is a service config file named wpa_supplicant@.service in /usr/lib/systemd/system, we could stop/disable the default service and start/enable the new wpa_supplicant@wlan0.service, which launch service like
/sbin/wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant-wlan0.conf -Dnl80211,wext -iwlan0
which is exactly how we want it to be. But the first launch could fail because /etc/wpa_supplicant/wpa_supplicant-wlan0.conf does not exist. So just make a copy or symbolic link from the origin wpa_supplicant.conf, named wpa_supplicant-wlan0.conf. You are good to launch it again and success.
Edward J
aGuegu
  • 121
I had a similar problem except for in /etc/network/interfaces I had two interfaces and was updating the wrong one! Ensure you're updating the correct interface.
I had the following and was updating wlan1 when I needed to update wlan0:
iface wlan0 inet static
iface wlan1 inet static
Mhaddy
I was unable to get wpa_cli to connect to wlan0 on a Raspberry Pi 3B+, when using a user other than the "pi" user. I received the same error messages. After some research, I found that running the command below will add the user that you specify to the "netdev" group, and the error goes away. You've got to reboot after running the command.
sudo gpasswd -a [username] netdev
You may also be able to use: sudo usermod -a -G netdev [username]
I know this is closed, but this is how they solved it. They just connected the resolv config to Google Public DNS.
  1. Edit /etc/resolv.conf from your terminal.
nano /etc/resolv.conf
  1. Add this to it:
nameserver 8.8.8.8
nameserver 8.8.4.4
  1. Reboot.
Amint
  • 111
I had the same problen. I had previously configured the Pi as an Access Point. So there was no entry in /etc/network/interfaces needed and none there.
After I added a network device to /etc/network/interfaces and rebooted, my problem disappeared
sudo cat > /etc/network/interfaces.d/20-wifi
auto wlan0
I solved my problem by adding the IP of GOOGLE to DNS because it was the problem
Balsam Qassem
  • 359
