I have been working with the Kali Linux distribution built for the Raspberry Pi Zero, and am running into a bit of a problem. It is running fine, but I am having trouble installing Raspbian packages on it. Specifically, I want to be able to access the Raspi Camera.
Here is my current sources.list:
deb http://http.kali.org/kali kali-rolling main non-free contrib
deb-src http://http.kali.org/kali kali-rolling main non-free contrib
deb http://archive.raspbian.org/raspbian wheezy main contrib non-free
deb-src http://archive.raspbian.org/raspbian wheezy main contrib non-free
But when I run apt-get update, this error is generated:
Reading package lists... Done
N: Skipping acquire of configured file 'main/binary-armel/Packages' as repository 'http://archive.raspbian.org/raspbian wheezy InRelease' doesn't support architecture 'armel'
N: Skipping acquire of configured file 'contrib/binary-armel/Packages' as repository 'http://archive.raspbian.org/raspbian wheezy InRelease' doesn't support architecture 'armel'
N: Skipping acquire of configured file 'non-free/binary-armel/Packages' as repository 'http://archive.raspbian.org/raspbian wheezy InRelease' doesn't support architecture 'armel'
root@kali:~#
I can still install any packages in the Kali repository fine, but when I try to install raspistill, apt-get says that it can't find the package raspistill.
What am I doing wrong? I have seen something online about Raspbian not supporting armel, (which is what the Zero runs), but is that true? If so, how do I get Raspbian repositories on the Raspberry Pi Zero?
As a secondary question, if anyone knows a way to access the RasPi Cam on a different distribution than Raspbian, please let me know. I have done extensive research and have not been able to get anything to work.
B00TK1D
  • 151
There is a tool called katoolin. You can use that software. The script is written in python. Just opne the software from terminal with
sudo python katoolin.py
and you will find options for everything
Katoolin
Sohan Arafat
  • 1,852
  • 43
Wheezy ("Old-Stable") is no longer the current distribution of Raspbian (and Debian from which it is derived) but not being familiar with Kali I am not sure from what it derives it's parentage - what do they say you should have in your sources.list currently - beware of using old documentation...!
Mixing repository sources is not a good idea unless a derivative distribution says it is OK to - they might suggest the "parent" from which they derived their own versions from - but only for the things they do not provide themselves, otherwise things can get broken quickly...
SlySven
  • 3,631
  • 46
