I got an error while trying to install phpmyadmin on my Raspberry Pi 3, the error message is:
dpkg was interrupted, you must manually run 'sudo dpkg --configure -a'
I think it's a problem related to the /var/lib folder, something went wrong and files got corrupted.
After running the command sudo dpkg -- etc... it seems everything is fine but when I try to install the package of phpmyadmin again, another error message appeared:
Error bus
rav_kr
  • 456
Niz.Dam
  • 325
Remove all the files inside /var/lib/dpkg/updates directory with the following commands:
cd /var/lib/dpkg/updates
sudo rm *
And then run this command to get the newer ones:
sudo apt-get update
Kong Chun Ho
  • 239
Niz.Dam
  • 325
