Do I need to show the taskbar on top of a full-screen page opened by google chrome browser?
Is it possible?
I tried to search but no results were found.
Thanks.
Mohi Rostami
  • 4,434
  • 39
AXn
The chromium-browser layer and the problem I was having where the taskbar didn't pop up from below because the windows covered it. I just edited the openbox config file (see source on how)
<application name="panel" type="dock">
<layer>below</layer>
</application>
to:
<layer>above</layer>
</application>
Source:
Graphical layers configuration do not stick after reboot
Clientroot
Try: Alt+F11 if on windows keyboard connected directly or remotely to the Raspberry Pi. If using Mac to connect remotely (via VNC or similar remote control), try Opt + F11 or Fn + Opt + F11.
This combination toggle full-screen mode on or off and will therefore make the browser window that is hiding the taskbar become a normal window again and show the taskbar.
The above assumes i understand your question correctly, meaning on startup of the RPi, a browser window set to ran at startup is coming up in full screen mode and does have window control (to close it) and in addition, is hiding the taskbar and withit the RPi menu.
ng10
  • 101
