This similar question has a lot of answers, none of which works anymore. Given that is already a little old, I'm asking the same quesion, for the current distribution of raspian (jessie 2017-04-10).
On startup, Raspbian checks the contents of the boot directory for specific files:
If it detects a file called
wpa_supplicant.conf, Raspbian will copy the file into/etc/wpa_supplicant, replacing any existingwpa_supplicant.conffile that may be there. The file in the boot directory is then removed.If an empty file named
sshis detected, Raspbian will adjust its settings to accept SSH connections. The ssh file is then deleted.
- 62,573
- 32
- 113
- 225
Firstly, plug the sd card into a computer. Then, there are basically three things that you probably want to do:
In order to connect to a wifi network, edit /etc/wpa_supplicant/wpa_supplicant.conf and add the following lines:
network={ ssid="my-network-name" psk="my-network-pass" key_mgmt=WPA-PSK }In order to enable ssh (disabled by default in jessie 2017-04-10), create an empty file simply named
sshin /boot/.Finally, plug the card into your raspberry and, from a computer that is also connected to the same wifi network, do:
ssh pi@raspberrypi.local
(instead of raspberrypi.local, you can write the ip address of the pi, but you need to know it somehow -e.g., by looking at your router clients list-).
- 141
- 1
- 5
