I have a new Camera Module V2 that I tried to hook up with a new Raspberry Pi Zero W with this adapter cable.
When I call raspistill -o test.jpg I get
mmal: Cannot read camera info, keeping the defaults for OV5647
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
I actived the camera and tried all the things from the troubleshooting section from this website: https://www.raspberrypi.org/documentation/raspbian/applications/camera.md
vcgencmd get_camera
shows
supported=1 detected=0
When I try the camera module with my Raspi 3 and the original cable it works fine.
Is there any way to check if the problem is the cable or the Pi zero?
I have a breadboard and a few leds, cables and things like that, in case I could use this to build something like an amperemeter.
