12
I'm new to Pi and Linux, and I'm using the Pi Zero W with a fresh version of Raspbian installed. I'm trying to get PyGame installed on the Pi so that I can work on a project. When I run the command
pi@raspberrypi:~/pygame $ python setup.py
This is the output:
No Arguments Given, Perform Default Install? [Y/n]y
WARNING, No "Setup" File Exists, Running "config.py"
Using UNIX configuration...
Hunting dependencies...
sh: 1: sdl-config: not found
WARNING: "sdl-config" failed!
Unable to run "sdl-config". Please make sure a development version of SDL is installed.
What does this mean in terms of the Pi? What can I do to fix this (some terminal commands would be great, I have no idea how to use the Debian Package Tracking System)
meabster
  • 123
An easy way to find the package providing a given file is apt-file; you can also do much the same thing online from here. First you need to install apt-file:
> sudo apt install apt-file
After that:
> apt-file search "sdl-config"
emscripten: /usr/share/emscripten/system/bin/sdl-config
libsdl1.2-dev: /usr/bin/sdl-config
libsdl1.2-dev: /usr/share/man/man1/sdl-config.1.gz
lush-library: /usr/share/lush/packages/sdl/sdl-config.lsh
You are almost certainly looking for something in a bin directory with no suffix, since this seems to be an in $PATH executable (since it was "not found" using only a base name), which probably excludes the first entry (since that directory is not in a standard $PATH). A more fine tuned way to do this search would be apt-file search "*/bin/sdl-config", which would give you only those two entries.
Anyway, most likely it is the -dev package, so:
sudo apt install libsdl1.2-dev
Should do it.
If you get more than one resulting package from your search, you may inspect the found packages for a description with:
apt-cache show <package-name>
libsdl1.2-dev has been chosen by the user, because emscripten and lush-library may pull several other packages from Java or Lisp. Thats a lot of extra stuff you may never use on your Pi.
Darth Vader
  • 4,218
  • 47
  • 70
Andur
