I'm using a USB 7 port hub that's rated 5V at 3.0A and get a lightning bolt symbol in Raspbian. There's nothing else plugged into it.
Shouldn't this work?
Thanks
Thanks
Your PSU isn't powerful enough. Try the official Raspberry Pi PSU. Also try plugging in a power adaptor to your USB hub if it has a jack.
Lightning bolt means undervoltage.
Measure the voltage you're getting out of your hub (with a multimeter, USB charge monitor, whatever) and on the power pins of your RPi. Either your hub is not supplying a high enough voltage, or your cable is bad enough to drop the voltage on the RPi side.
Also, a "3A" label doesn't magically turn a bad power supply into a good one.
