I am trying to read an ads1115 monitoring a current shunt so it's reading in millivolts. All I need is to be able to read the serial output from the arduino serial. When I bring the arduino up with the IDE in macos sierra I get changing one or two digit values. I'm confused, am I reading the serial wrong in the Python? I know I have the correct port and only one arduino is plugged in.
Arduino code:
Adafruit_ADS1115 ads;  /* Use this for the 16-bit version */
void setup(void)
  Serial.begin(9600);
   ads.setGain(GAIN_SIXTEEN);    // 16x gain  +/- 0.256V  1 bit = 0.125mV  0.0078125mV
  ads.begin();
void loop(void)
  int16_t results;
  results = ads.readADC_Differential_0_1();
  Serial.println(results);
  delay(1000);
Python code on RPi:
import io
import sys
import serial
import time
logfilename = 'temp' + time.strftime("%Y-%m-%d")
file = open('/home/pi/' + logfilename + '.log', 'w+')
ser = serial.Serial('/dev/ttyACM0', 9600)
ser.flushInput()
ser.flushOutput()
while True :
    try:
        bytesToRead = ser.inWaiting()
        state=ser.read(bytesToRead)
        file.write( "%s\n" % (state) )
        time.sleep(1)
    except ValueError:
        print "error"
file.close()
What is contained in the file
pi@pi:~$ more ~/temp2017-04-01.log
What I see from the IDE serial monitor:
11
12
Edit: I didn't figure it out, but I did get an ethernet shield and webserver to work. I'm still curious why this didn't work.
Rich
The Arduino outputs each result with a line terminator.
I suggest you use a blocking read line at the Pi.
while True:
   line = ser.readline()
   file.write("%s\n" % (line))
joan
  • 71,852
  • 76
  • 108
First, are you sure you connected the cable right? Also, I think the Raspi comes with the serial configured for terminal emulation, you have to do something to make it available for your programs. See this: How do I make serial work on the Raspberry Pi3
Radu
  • 480
