I've read multiple threads about streaming a Logitech C920 Webcam via raspberry pi with cvlc using basically this command:
cvlc v4l2:///dev/video1:chroma=h264:width=800:height=600 --sout '#standard{access=http,mux=ts,dst=localhost:8080,name=stream,mime=video/ts}' -vvv
Taken the info from this site: https://wiki.matthiasbock.net/index.php/Logitech_C920,_streaming_H.264
When I use this command, I don't get any output with the Logitech C922. VLC fails to get the h264 stream and says that it only gets the YUYV Stream, which is not compliant to the resulting ts stream. (The h264 stream seems to be transported inside the mjpeg stream)
The Problem is also covered in this recent Blog Post: http://w2017.pl/logitech-vlc-ffmpeg-c922-streaming/
Is there some way around that? I already have audio working with
:input-slave="alsa://hw:1,0" --sout '#transcode{acodec=a52,ab=32}'
Thanks for any hints on how and when this will be resolved.
Output of v4l2-ctl --list-formats:
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Index : 1
Pixel Format: 'MJPG' (compressed)
Output of v4l2-ctl --all:
Driver Info (not using libv4l2):
Driver name : uvcvideo
Card type : C922 Pro Stream Webcam
Bus info : usb-3f980000.usb-1.4
Driver version: 4.4.50
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Width/Height : 800/600
Pixel Format : 'YUYV'
Field : None
Bytes per Line: 1600
Size Image : 960000
Colorspace : SRGB
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 800, Height 600
Default : Left 0, Top 0, Width 800, Height 600
Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 800, Height 600
Selection: crop_bounds, Left 0, Top 0, Width 800, Height 600
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 24.000 (24/1)
Read buffers : 0
brightness (int) : min=0 max=255 step=1 default=-8193 value=128
contrast (int) : min=0 max=255 step=1 default=57343 value=128
saturation (int) : min=0 max=255 step=1 default=57343 value=128
white_balance_temperature_auto (bool) : default=1 value=1
gain (int) : min=0 max=255 step=1 default=57343 value=0
power_line_frequency (menu) : min=0 max=2 default=2 value=2
white_balance_temperature (int) : min=2000 max=6500 step=1 default=57343 value=4000 flags=inactive
sharpness (int) : min=0 max=255 step=1 default=57343 value=128
backlight_compensation (int) : min=0 max=1 step=1 default=57343 value=0
exposure_auto (menu) : min=0 max=3 default=0 value=3
exposure_absolute (int) : min=3 max=2047 step=1 default=250 value=250 flags=inactive
exposure_auto_priority (bool) : default=0 value=1
pan_absolute (int) : min=-36000 max=36000 step=3600 default=0 value=0
tilt_absolute (int) : min=-36000 max=36000 step=3600 default=0 value=0
focus_absolute (int) : min=0 max=250 step=5 default=8189 value=0 flags=inactive
focus_auto (bool) : default=1 value=1
zoom_absolute (int) : min=100 max=500 step=1 default=57343 value=100
led1_mode (menu) : min=0 max=3 default=3 value=0
led1_frequency (int) : min=0 max=255 step=1 default=0 value=24
