I have a setup like below:
The script is supposed to turn the led on, sleep and turn it off again. And the script does work.
import RPi.GPIO as GPIO
import time
# This script will turn on the LED for 1 second and turn it off again
# setup GPIO
GPIO.setmode(GPIO.BCM)
# disable warnings
GPIO.setwarnings(False)
# set GPIO.OUT to pin 18
GPIO.setup(18,GPIO.OUT)
# turn on LED
print "LED on"
GPIO.output(18,GPIO.HIGH)
# wait for 1 second
time.sleep(1)
# turn off led
print "LED off"
GPIO.output(18,GPIO.LOW)
If I reboot the pi the led suddenly is on again and I wonder why. Is it because I am missing something important about the pi's functionality or am I making mistakes here? By the way the same behavior occurs with rgb leds too.
I also read up on GPIO.setmode(GPIO.BCM) and it seems that the only difference between the modes BCM and BOARD are the number one uses when referring to pins, or might the mode be the issue?
チーズパン
  • 167
You can't guarantee the state of the GPIO pins during the boot process; all sorts of things from the kernel configuration, device tree, modules etc can mess with this.
See Why are some GPIO pins HIGH when the Raspberry Pi boots up?
You could run a script from /etc/rc.local to reset this pin on boot, as described here.
nickcrabtree
  • 438
Try to cleanup the GPIO pins to restore them to low state. Try the following code for example:
import time
PIN = 12
# blinking function
def blink(pin):
        GPIO.output(pin,GPIO.HIGH)
        time.sleep(1)
        GPIO.output(pin,GPIO.LOW)
        time.sleep(1)
        return
# to use Raspberry Pi board GPIO Board Numbering
GPIO.setmode(GPIO.BOARD)
# set up GPIO output channel
GPIO.setup(PIN, GPIO.OUT)
# blink GPIO18 10 times
for i in range(0, 10):
        blink(PIN)
GPIO.cleanup()
I have modified the code from the site a bit to match your code's pin numbers.
Tes3awy
  • 323
