One of my raspberry pi's is hanging whenever I try to install or update anything using apt-get.
Running Raspbian 7 (wheezy).
Symptoms (using watchdog as an example as it has no dependencies):
# apt-get install watchdog
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
  watchdog
0 upgraded, 1 newly installed, 0 to remove and 129 not upgraded.
Need to get 0 B/81.7 kB of archives.
After this operation, 209 kB of additional disk space will be used.
Preconfiguring packages ...
Selecting previously unselected package watchdog.
(Reading database ...
... at which point it hangs. Ctrl-C doesn't even work to kill it; I've been using Ctrl-Z and then kill %1 to get rid of it.
By hanging, I mean nothing happens for over 24 hours wall clock time.
Running with strace ends with the last 2 lines endlessly repeating:
wait4(6254, 0xbee07570, WNOHANG, NULL)  = 0
pselect6(18, [0 15 17], NULL, NULL, {1, 0}, {[], 8}) = 1 (in [17], left {0, 448307553})
read(17, "Selecting previously unselected "..., 1024) = 49
write(1, "Selecting previously unselected "..., 49Selecting previously unselected package watchdog.) = 49
write(4, "Selecting previously unselected "..., 49) = 49
pselect6(18, [0 15 17], NULL, NULL, {1, 0}, {[], 8}) = 1 (in [17], left {0, 999814003})
read(17, "\r\n", 1024)                  = 2
write(1, "\r\n", 2^M                                                          )                     = 2
write(4, "\r\n", 2)                     = 2
pselect6(18, [0 15 17], NULL, NULL, {1, 0}, {[], 8}) = 1 (in [17], left {0, 999947001})
read(17, "(Reading database ... \r", 1024) = 23
write(1, "(Reading database ... \r", 23(Reading database ... ^M) = 23
write(4, "(Reading database ... \r", 23) = 23
pselect6(18, [0 15 17], NULL, NULL, {1, 0}, {[], 8}) = 0 (Timeout)
Top indicates the pi is 98% idle (the 2% active is basically the top command itself). This is a headless pi not running X so has plenty of free memory. Status lines from top (during a "hang") are:
Tasks: 104 total,   1 running, 103 sleeping,   0 stopped,   0 zombie
%Cpu(s):  1.0 us,  1.3 sy,  0.0 ni, 97.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0
KiB Mem:    184900 total,   158188 used,    26712 free,    28336 buffers
KiB Swap:   102396 total,        0 used,   102396 free,    67240 cached
There is sufficient free disk space. df -h gives:
Filesystem                    Size  Used Avail Use% Mounted on
/dev/root                     3.4G  2.5G  757M  77% /
devtmpfs                       87M     0   87M   0% /dev
tmpfs                          19M  264K   18M   2% /run
tmpfs                         5.0M     0  5.0M   0% /run/lock
tmpfs                          37M     0   37M   0% /run/shm
/dev/mmcblk0p5                 60M   21M   39M  36% /boot
Things I have tried which don't make any difference:
  • rpi-update (Suggested by a similar issue here)
  • apt-get update (which works) followed by apt-get upgrade (which hangs)
  • Copying the status-old file over the existing status file in /var/lib/dpkg
  • apt-get install -f (hangs)
  • dpkg --configure -a
  • dpkg --clear-avail
nickcrabtree
  • 438
This is what I would do:
  1. Exclude filesystem issues by running fsck and fixing errors if any
  2. Run apt-get clean and apt-get autoremove followed by an update/upgrade
  3. Backup&remove /var/cache/apt and /var/lib/apt/lists, and run update/upgrade to recreate them. You may need to manually recreate the lock file and some directories.
  4. Look though your strace log to find out which file it tries to access and backup&remove that file to see if it can be recreated. Depending on which file it is, manually fixing the file may be an option.
Having said that, broken package databases can be a real mess. It already happened to me to give up, back up my files and reinstall. It will be an opportunity to upgrade to Jessie, too.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
I was seeing the same problem. I ran with strace, but the logging had a lot of error messages about bad file descriptors so it was taking a long time. On a whim, I simply deleted the same file that you did: python3.list - and it fixed the problem. So clearly, there is something about this file which can cause a repeatable hang.
Bob
  • 46
some of this are CPU / IO intense processes. Open a second terminal and check if CPU is on 100%. Try to shut down some of the processes that consume high CPU. There can be different reasons why the system becomes unresponsive. Maybe you can find an hint in the logs.
tail /var/log/apt/
Sometimes people recommend nice
sudo nice apt-get install watchdog
Sometimes this hangs are traced back to memory issues. An indication can be if the CPU is not at 100%. The system seems to be unresponsive while swapping memory to SD card. Also check if there is sufficient space on your SD Card.
free -m
can be an option to get some more memory during the apt-get process. If you run your raspberry without GUI try to reduce the memory allocated for graphics.
Joe Platano
  • 852
