I'm currently trying to access a Bosch BMP280 pressure sensor from Haskell using the HPi wrapper for the bcm2835 library.
I have no experience in handling SPI at all and as documentation is extremely brief / sparse, I had no success trying to troubleshoot the problem on my own.
As far as I understand, to read from the chip's registers, I have to clock out the address of the register to be read (with the first bit of this being replaced by a '0' to enter read mode)and then clock in as many bits as I want to read (by clocking out the corresponding number of Bits / Word8's of zeros while returning the bits being clocked in at the same time). In code (following the spitest.hs from the HPi GitHub repo):
import System.RaspberryPi.GPIO
import Control.Concurrent
import Control.Monad
import Data.Bits
import qualified Data.ByteString as BS
import Data.Word
main = withGPIO . withSPI $ do
chipSelectSPI CS0 --set the Chip select pin to the CS0 pin
setChipSelectPolaritySPI CS0 False --The BMP chip needs CS to be pulled low
setDataModeSPI (False,False)
transferManySPI [244,47] -- write 0xF4 = 244 settings 00101111 = 47
transferManySPI [245,160] -- write 0xF5 = 245 settings 10100000 = 160
threadDelay 10000
printReadout
printReadout :: IO()
printReadout = do
transferManySPI [122,0] >>= (print) -- read 0xFA = 0x7A = 122
Is that correct?
With this code I get nothing than [0,0] back from the sensor.
Starting to guess what the problem might be, as the bcm2835SPIClockDivider enumeration type from the library seems not to be handled in any way in HPi, I wonder about if there is a default clock divider / clock speed used by the library and if it possibly exceeds the maximum of 10 MHz mentioned in the sensor's manual. Is that the case?
