I am trying to setup an audio player in Python using vlc.py bindings, but the simplest of code seems to throw an error. I want it running headless so I am trying all my experiments over SSH.
Code
import os
import sys
import vlc
p = vlc.MediaPlayer("iwyb.mp3")
p.play()
while(1):
continue
I have also tried
import os
import sys
import vlc
if __name__ == '__main__':
filepath = "iwyb.mp3"
movie = os.path.expanduser(filepath)
if 'http://' not in filepath:
if not os.access(movie, os.R_OK):
print ( 'Error: %s file is not readable' % movie )
sys.exit(1)
instance = vlc.Instance() # <-- what goes here?
try:
media = instance.media_new(movie)
except NameError:
print ('NameError: % (%s vs Libvlc %s)' % (sys.exc_info()[1],
vlc.__version__, vlc.libvlc_get_version()))
sys.exit(1)
player = instance.media_player_new()
player.set_media(media)
player.play()
while(1):
continue
Error (in both cases)
[01a7f9a0] pulse audio output error: PulseAudio server connection failure: Connection refused
[019f0978] pulse audio output error: PulseAudio server connection failure: Connection refused
[019f0978] alsa audio output error: cannot commit hardware parameters: Invalid argument
[019f0978] core audio output error: module not functional
[b4d114d8] core decoder error: failed to create audio output
However if I run the vlc player command line version I get the following errors but the song plays
cmd
cvlc iwyb.mp3
Output
VLC media player 2.2.1 Terry Pratchett (Weatherwax) (revision 2.2.1-0-ga425c42)
[005196a8] pulse audio output error: PulseAudio server connection failure: Connection refused
[00527ca8] core interface error: no suitable interface module
[0048a8f8] core libvlc error: interface "globalhotkeys,none" initialization failed
[00527d10] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[00527d10] core interface error: no suitable interface module
[0048a8f8] core libvlc error: interface "dbus,none" initialization failed
[00527ce8] dummy interface: using the dummy interface module...
aplay -l gives the following
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpijustboomd [snd_rpi_justboom_dac], device 0: JustBoom DAC HiFi pcm512x-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
I guess, I am missing a magic string here somewhere. I have seen in the wild people pass around strings to the Instance constructor so my question is what is this magic string and where can I find more information about it? Apart from the sparse API documentation I haven't made much progress.
