I have a Raspberry Pi being used as a media server kind of system in my home. I have 2 internet connections, Router-1 192.168.1.1 is right next to Pi along with my PC and both are connected to Router-1 via it's ethernet ports.
Router-2 192.168.1.100 is in other room but has much better wifi coverage in rest of the house compared to Router-1.
On Pi, I'm running Transmission and miniDLNA.
My requirements are:
1) Pi should be accessible to all devices connected to wifi of Router-2.
2) The torrents and other downloads on Pi should use Router-2 wifi.
3) Pi should be accessible via SSH, NOmachine etc on my PC which doesn't have wifi.
For this, I've tried various combinations without any luck. Pi always connects to Router-1's wifi by default and I have to change it manually to Router-2 everytime. After I added Priority in wpasupplicant.conf file, Pi is connecting to Router-2 first, but the files on it (incuding minidlna) are not accessible to other devices connected to Router-2 wifi.
What changes do I need to make ?
Following is interfaces.conf file.
auto lo
iface lo inet loopback
iface eth0 inet dhcp
iface eth0 inet static
     address 192.168.1.21
     network 192.168.1.0
     netmask 255.255.255.0
     broadcast 192.168.1.255
     gateway 192.168.1.1
allow-hotplug wlan0
iface wlan0 inet manual
iface Router-2 inet static
address 192.168.1.20
gateway 192.168.1.100
#auto wlan0
#iface wlan0 inet static
#address 192.168.1.22
#netmask 255.255.255.0
#gateway 192.168.1.100
#wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
#allow-hotplug wlan1
#iface wlan1 inet manual
jjamwal
1) First since the release of Jessie, many tutorials or past posts of changing the /etc/network/interfaces became obsoleted. It was common in previous OS release to make changes directly to the /etc/network/interfaces for network configuration. When using Jessie, it will be necessary to make changes through /etc/dhcpcd.conf.
2) As mentioned by @Millways, your configuration doesn't make sense. If your netmask is 255.255.255.0, then both of your routers are actually on the same network instead of what you said on two different networks. Therefore you should check both of your router configurations and provide more information so that others can help you.
3) Since we don't have sufficient information on how your two networks are configured. But in general, if you have two sub networks (e.g. 192.168.1.0/24 and 192.168.2.0/24 with an assumption of netmask of 255.255.255.0), in order for each network to be able to communicate with the other, you need to setup a static route at router A with settings like route add 192.168.2.0 255.255.255.0 gw 192.168.1.21 (as per your example), and another static route at router B as route add 192.168.1.0 255.255.255.0 gw 192.168.2.22. These can be done at routers. On the raspberry pi, you will need to setup your wlan0 ssid credentials to connect to router B. Hope this give you a general direction to work it out.
hcheung
  • 865
