I'm newbie on Raspberry Pi.I have installed serial port using following conmand on raspian l os.
sudo apt-get install python-serial
I'm trying to access serial port communication on Raspberry Pi 3. I have created script using python. When I run the script, I got following error.
Error: serial device '/dev/ttyAMA0' does not exist
But When I used /dev/ttyS0, it's working fine. Why?
My script here.
import serial
port = serial.Serial("/dev/ttyAMA0", baudrate=9600)
while True:
    port.write("Hello world")
    rcv = port.read(10)
    print rcv
rsp
  • 622
You have NOT "installed serial port", although you may have installed python-serial
I don't know why you would get serial device '/dev/ttyAMA0' does not exist, because it SHOULD, although it is connected to Bluetooth, unless you have changed something.
In contrast /dev/ttyS0 SHOULD not exist, because it is disabled by default, again unless you have changed something. (It is possible installing python-serial may have done this.)
The only conclusion is that you have executed some other commands, you are not telling us about.
See How-do-i-make-serial-work-on-the-raspberry-pi3 for an explanation.
PS as outlined in the above you now use /dev/serial0, which should work on all models.
