I want to use my Raspberry Pi 3 as a server so I want to connect it via a socket. At first time everything was fine but now I cant connect any more.
I get this error: ConnectionRefusedError: [WinError 10061] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte My Os is raspbian.
So here is my server code:
import os
import sys
import pickle
import socket
import time
mail_path="/home/pi/Desktop/Pi_Secure/mail"
picture_path="/home/pi/Desktop/Pi_Secure/picture"
Video_path="/home/pi/Desktop/Pi_Secure/video"
key_path="/home/pi/Desktop/Pi_Secure/key"
main_path="/home/pi/Pi_Secure"
host="192.168.178.45"
port= 5001
s=socket.socket()
s.bind((host, port))
print("Server is online at "+host+":"+str(port))
def get_data():
global host
global port
global picture_path
global Video_path
global key_path
name=None
s.listen(1)
c ,addr=s.accept()
print("Connection established to"+str(addr))
data=c.recv(1024)
data=data.decode("utf-8")
dataMessage=data.split(" ", 1) #split data in command a picture or text Dokument
command=dataMessage[0]
if command=="mail":
os.chdir(mail_path)
mail=open(mail_path,"wb")
Mail=c.recv(1024)
while Mail:
mail.write(Mail)
Mail=c.recv(1024)
if not mail:
mail.close()
break
if command=="key":
os.chdir(key_path)
key=open(key_path,"wb")
Key=c.recv(1024)
while Key:
key.write(Key)
Key=c.recv(1024)
if not key:
key.close()
break
if command=="picture":
os.chdir(picture_path)
picture=open(picture_path,"wb")
pic=c.recv(1024)
while pic:
picture.write(pic)
pic=c.recv(1024)
if not pic:
c.send("ok")
picture.close()
break
if command=="Del":
try:
t=os.listdir()
except OSError:
t="Nothing is in this Diretory"
o=t,encode("utf-8")
c.send(o)
c.close()
o=t.encode("utf-8")
c.send(o)
pickname=c.recv(1024)
Picture=pickname.decode("utf-8")
os.remove(Picture)
c.send(str.encode("True"))
while True:
if os.path.exists(main_path): #this should check that everything what is important be existent
get_data()
if socket.error:
get_data()
else:
os.chdir("/home/pi/Desktop")
os.mkdir("Pi_Secure")
os.chdir("/home/pi/Desktop/Pi_Secure/")
os.mkdir("pictures")
os.mkdir("mail")
os.mkdir("key")
get_data()
global c,addr
c.close()
