I have a Raspberry Pi 3 with an external WiFi antenna wlan1 set up as an independent IoT access point without Internet connection following this tutorial, using hostap and isc-dhcp server. I omitted the Network Access Translation part. The AP worked well up to the point when I tried connecting wlan0 to my router at home for accessing the Internet via the GUI.
My /etc/network/interfaces looks like this
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa/supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet static
    address 192.168.42.1
    netmask 255.255.255.0
I setup the daemon
sudo service hostapd start
sudo service isc-dhcp-server start
and
sudo update-rc.d hostapd enable
sudo update-rc.d isc-dhcp-server enable
and this all worked before I started messing with wlan0.... But now on boot when hovering over the GUI it says "wlan1: Disassociated from Pi3AP" and sudo service hostapd status prints
Loaded: loaded (/etc/init.d/hostapd)
Active: active (exited) since ... 31 mins ago
Process: 571 ExecStart=/etc/init.d/hostapd start (code=exited, status=0/SUCCESS)
The command
sudo service isc-dhcp-server status
returns an error
raspberrypi dhcpd[778]: receive_packet failed on wlan1: Network is down
When I run
sudo /usr/sbin/hostapd /etc/hostapd/hostapd.conf
all works again but nothing on reboot. Can someone spot at where the error lies? Somehow the network GUI and/or the two wlan interfaces seem to be interfering with each other.
birgit
  • 71
