Pulled a fresh rPi3 out of the cupboard and installed JessieLight (2017) on it. Added the file 'ssh' to the root of the sd card to enable the by default disabled ssh; put the SD into the Pi, network cable and power; red LED on, green blinking... rPi3 acquired IP address via DHCP; I can ping it, nmap shows port 22 is open... however, when connecting via laptop on Mint, I get an error: ssh Read from socket failed: Connection reset by peer
If I try to connect from a windows 10 PC I get: Network error; Software caused connection abort
I have no clue what to do next, given this is a new install, on a new Pi, without any other software than the Jessie light image and the file ssh to run a headless pi. I have changed the SD card, wrote image, added ssh file and same result.
There are other rPis (running Jessie 2016) on the network I can connect to w/o problems.
Any help appreciated.
[edit] And no, this is not a duplicate of existing ssh problems on fresh installs.
MaxG
  • 133
I ended up connecting a monitor to the Pi... and it showed a yellow lighting bolt at the top right conrner = indicating under voltage. The power supply was good and sufficient, but the USB cable had only hair thin wires in it, which went in the bin and was replaced with a 22AWG (6 AUD) cable.
Now the Pi works!
I checked the voltage on the old cable, which dropped to 0.5V on start-up, while the better cable dropped to 4.6V at start-up.
Thank you for your input and sorry for wasting your time!
It proves the point again: if a new rPi is showing the weirdest signs of behaviour > check power supply and USB cable!
MaxG
  • 133
